Rear handbrake calipers
dingla rs (09-06-2016)
1st to 200 without NOS
The std 4x4 caliper can be used just for handbrake purposes, normally in conjunction with a 330x28mm disc / 4 pot caliper. This requires a bracket to move the OE caliper outwards and machining to the pad carrier to allow the wider disc.. Also needed are thinner pads.
Reyland do a kit, hence Martin knowing so much. Buy his, no hassle fit.
I have a normal rear calliper if you want to try it. The hand brake is sticky but they normally oil and free up. Had all new seals throughout and freshly painted black. You can have it for free if you want it mate it is near side
dingla rs (10-06-2016)
And thanks for the offer , my rear cosworth calipers are brand fire new , as say my new 4 pots have the machines brackets that bolt were the cosworth item did so in looking to move the standard down just for hand brake , il have a mock up an see what I need cheers
jasoft
05-05-2016 06:24 PM
Caddyshack
20-04-2016 07:50 AM
