View Full Version : General Car Related Discussion.
- Radio quiet after battery change
- Does anyone make replacement saff cos seat mounts under floor
- Focus ST 431bhp advise
- High Pressure Diesel fuel pump
- Diesel not going without a fight
- Mondeo st200
- Rough idle
- Cossie and rs turbo seat belts????
- Ford S-max Radio Turning it's self off and on
- Fiesta 1600 CVH
- Basic Pinto info...
- 2wd cosworth pump blank
- Anyone ever regretted selling a car?
- An insight into motor oil development
- Any images of YB external oil return setup from head?
- Sierra type 9 power limit ??
- Heaters not heating up?
- Built to be used
- CVH on Bike carbs
- Cosworth heater matrix sapphire - escos replacement
- Ford spare parts webiste?
- Blacktop zetec turbo
- El escort xr3i mk5 covecion rs
- FAO bodyshop people - replacing a bumper + paint of a Nissan note costs
- Best oil to use CVH
- Semi auto fiesta
- 2wd diffs
- Fiesta engine conversion
- Rear diff ratio
- Walbro 255.... loud???
- Jaz fuel cell
- pics needed asap crazy cage mounts /mk4 escort
- Rear Wheel bearing whats easiest, fusion / fiesta
- brake flexys
- Burton power
- Official Mobile Ford Servicing
- Ford Fiesta - Bonnet Opening
- Traction Control button in older Fords
- How hard is it to fit a Ford Ka 2010 heater matrix?
- Its a mystery!!
- Galaxy 2.0 TDI 2009
- Vehicle health checks
- Group A ignition coil
- Bespoke intercooler ..cores .
- Drilled through my fuel tank, help!
- Car S.O.S returns this week
- Mk6 Fiesta WRC Spoiler
- my new ford sierra
- transit mk7 people
- What do i need to lift a ford ranger 2013?
- Its WAX time! .. What do you use?
- Thinking of purchasing a 2wd Saph
- Mk4 Mondeo tdci fault
- Facebook RSOC group
- anybody in st leonards on sea willing to pick up and post a tyre to me
- Series 2 rs turbo header tank
- Diff ratios. MK1 ESCORT PROJECT.
- Any engineers on here .
- "Quoted" time to change tie rods and control arms from garage - does this sound ok?
- CVH exhaust manifolds .
- Painted calipers - opinions
- ** Crackle or Chrome **
- 3 Door front brake help
- Diagnosing knackered tie rod ends vs rack
- crail 1/4 mile "the big one" event with Fast Car....
- RS2000 in escort mk4 how to connect engine ?????
- recommend me some under body protection
- Mk3 escort immobiliser
- Mondeo mk3
- Anyone tiger striped an ST220
- Advice if Possible? Mk 6 RS 2000
- 2.0 twin cam efi into sierra 1.6 pinto
- Ford fusion semi auto box help needed
- EFR 7064 with standard head bolts.
- Specing a cossie
- Fitting a black top Zetec / Mk1 Focus RS engine into a mk5 fiesta Zetec S?
- XR2i 1.8 16v engine info on what I need & do not need to run carburettors
- Mk4 escort van lowering
- Anybody know much about a grey rs turbo reg no. F713 UPA?
- Need help identifying inlet manifold
- Mot/tax question...
- S1600
- RIP Rod Tarry .
- Harness recommendations
- Powershift Box..
- New Focus RS Heritage Edition
- Anyone got or had a Mitsubishi 3000GT/GTO
- New addition being collected tomorrow
- Transit egr pipe repair??
- Mk5 fiesta 1.7 puma engine track car- how can I make more power??
- Mondy MK3 2.5 V6 gurus needed!
- Cosworth t5 gearbox info needed.
- Gartrac information sought
- Ford Focus 5th Gear
- Focus ST mk2 keyless entry
- 2wd Saph, Head Issue?
- top gear returns
- 1800TDCi glow plugs
- MK2 Focus RS Borg Warner EFR
- 4wd turbo oil drain
- Opie Oils
- Urgent help required, MK3.5 Fiesta hubs?
- Opie Oils
- 18in Escort Cosworth alloys....
- code readers passionmercedes
- Need peoples expertise to help me
- plastikoat paint???
- 3 door rear drop links
- Temp gauge
- Cosworth yb dimensions
- Fitting a rear spring lowering kit
- Mk3 Escort XR3i Earth point
- Transit passenger seat
- Car insurance
- Paint Work
- Exploded view of cosworth throttle body
- On Quest, Capri and 2017 Mustang V8.
- 2002 Focus starting / running problem
- Diesel mechanic help needed!!
- Moonstone damaged in Devon
- Transit only starts when jumped.
- Do I scrap it?
- Car goes into Limp Mode No Warning Lights
- Brakes!! Help!
- Fiesta zetek s 20v project
- Anyone know the whereabouts of this RS2000?
- Badge colour
- Carbon Fibre RS500 Upper Spoiler - Where to buy from?
- Magneti Marelli L8/P8 datastream decoding
- Sump help - st170 into p100
- Cosworth for MK2 RS2000
- ST150 intake manifold bolt fitment
- Best way to paint a dash
- Modified Focus ST2 MPG
- What Are Sapphire Cosworths Actually Selling For?
- Stolen Focus RS found ?
- Cosworth trailing arm spherical bearings, dimensions?
- Why is the post about rods car now locked?
- Erm wow
- Focus ST2
- Severn valley Motorsport competition??
- EML,EML
- rod is selling his saph?
- Fiesta ofab ecu wiring
- Useable power 2wd road car
- Focus mk1 chargcooler..
- Waterless coolant
- Anyone used the windown seals from east kent trimmers?
- Anyone stripped a car and sold the parts?
- Degas Hose
- Referbushing 2wd driveshaft
- 2005 ford transit 280 loss of power
- How can I find out what size master cylinders I need?
- Dashboard Going Crazy
- Any good Greddy dealers in the UK
- Focus ST170 wheel question
- Ib5 gearbox ratios .
- escort cosworth clock/temperature pin out
- Capri - advise on rolled arches for bigger wheels and lowering...
- Brake drum conversion mk2 focus 1.8 zetec
- Tyre pressures
- 1500 quid for 4 rivets😮😂😂😂
- mondeo mk3 tdci injectors
- 360bhp rs turbo.
- Did anyone watch....
- bosch super 4 spark plugs st170
- Notchy latest Focus RS gearbox.
- Wanted MK1 Ford Focus RS Gearbox. Or a mtx 75 with quaife
- Celette M8 data sheets
- Anyone have a built in Sat Nav?
- Having a car run in on dyno .
- Help Please: Slave cylinder leaking Mondeo tdci 2006
- Oil change, too early?
- T5 gearboxes how many?
- Turbo choice's
- Cossies on MK5 Fiesta
- my new granada mk3
- Zetec turbo Sierra rev counter help?
- Cosworth TPS .
- Mk3/4 escort compbrake tcas
- St150 common faults
- Help needed on parts asap
- caught speeding, 50mph in a 40mph limit 😠
- Cougar thoughts
- Focus RS being raffled off?
- shit brakes on mk4 escort track car
- People's thoughts on which cooler I should use
- speed detection question
- help! does the ford focus rs mk1 turbo engine have same mounting points
- Rs Turbo fuel pumps
- been offered a rs focus engine
- Ford focus mk2.5 1.6tdci turbo question
- Advice on turbo charging a ford based kit car
- mk3 focus rs boost pressure
- Camb belt change
- Newbie
- Mondeo st220
- wow any one seen these socket extensions
- Going to make you feel old now!
- MK3 Focus ST Rear facing car seat
- New wheeler dealers...
- 2013 Fiesta fan speed control fault
- Cosworth breakers
- 2015 Focus Zetec S Tdci
- The BOA, 2.9 V6 cosworth engine. Any info before I start??
- 2007 focus mk2 2.0 petrol miss fire issue, any help appreciated?
- Any ideas with these vinyl wraps?
- DAB radio...Help
- 3 door spoiler brackets
- new fangled jump starter packs..help
- Good idea/bad idea, Lexus for Mondeo?
- Gtd golf 2014/15 info wanted
- side door moulding 3 door
- Advice on Tom Tom
- drl
- Focus 1.6tdci dpf filter and how to clean
- Ford Mondeo st 220
- Garrett New G25-550, 660
- Fibre motorsport
- Home invasion focus RS
- 2wd big wing sump. Who converts them ?
- 3.9 drop gears 4x4 cosworth
- Dilemma with cars. Get rid or keep 😩😑😔
- Driving when its nearly dark with no lights!!!
- So true
- AP racing brake bleed nipple dust covers .
- upol acid etch primer - how many use this stuff on bare metal?
- any tips for getting rain x off windscreen, got it off now
- Mk3 fiesta rear axle
- Carry on Cabby - MK1 Cortinas
- YB Cossie engine overhaul
- commpomotive TH and rallye diference?
- Tennis escort cabriolets
- Where to buy WRC breather.
- Who had that 300 brake Mondeo then?
- Holset hx35 on 2wd cosworth exhaust manifold
- Is this a gel type battery?
- Stereo code
- Any escort cosworth for sale
- NVQ level 3 or equivalent? MOT testers course
- T5 Cossie box with cracked casing
- T5 g/box lever gaiter?
- About to by an 86 XR2..
- Look at the size of this Mercedes
- Pic's, Specs, Info on 2 x old 3 Door Cosworth's
- New Transit Connect
- NEED HELP!!!! Escort cosworth
