Cosworth yb dimensions
As title cosworth yb engine dimension from front of block to the rear , and height from shallow sump to top of cam cover and rear of sump to top of cam cover .
On a 4x4 engine please
Even better a picture with tape measure next to it would be great.
Cheers Paul
Cheers Paul
I can do this on Friday for you. Can't remember where you are based, you can and measure if you want.
I'm in derby mate but working away this week so got no chance of going anywhere . I would be really greatful if you would take some measurements or pics with a tape measure next to the engine as there seems to be no info anywhere about yb apart from 1 technical drawing from cosworth but has no sump on etc so useless.
Iam not using yb iam using zetec but need to know how the sizes compare before I start cutting the car to pieces lol.
No worries wil, do some pics with tape measure for reference
Front of pulleys to back of block
Dimpled part of sump to top of cam cover
Back of block to front of thermostat housing
I can do more and with steel tape if needed but I guess this gives you rough enough? , it was hard to take the pic and hold the tape.
Cheers mate that's brilliant , the only other one I could do with is top of cam cover to the bottom of the deepest part of the sump please but only at your pace as not in any rush.
Cheers for the help
Paul
Cheers for the help
Paul
No worries, Paul. Will do that over the weekend.
3FRD
11-11-2008 07:46 AM
big_wig_074
23-06-2008 09:19 PM
Graceland
26-06-2006 09:05 PM
