MK2 Focus RS Borg Warner EFR
PF's Guitar God!!!
Evening all
just some advice needed for those who are using BW EFR turbos on their MK2.
Looking for 400/460bhp and want to know what EFR Turbo is a good suit for the RS' 5pot?
cheers
cheers
I bet it is the 7064
As said, if you are stopping at 4-460ish then either the standard turbo is fine or a hybrid if you want it to hold a boost a bit stronger at the top of the revs. Have a chat with Jason at JW Racing about hybrids and what you want. Failing that if you're dead set on an EFR give Devil Developments a ring. Lee should be able to spec an EFR to suit what you need rather than just going for an off the shelf jobby.
Regards,
Tom
PS forgot to mention, my mk2 FRS is on the standard turbo and is CP400. CP420 HT/Revo 4+ etc run standard turbos as well and pull like trains.
Regards,
Tom
PF's Guitar God!!!
If I'm going for 400/470bhp then I'd like a turbo for 550bhp simply because I don't want to be on the limit of the turbo. Would still like some room for a little more as it'll be set up on an EMU ECU
7064 does 530 max on a cossie 2.0
You won’t get 550 from a 7064
They are a 500hp rated turbo.
I would give devil developements a ring as they know they’re stuff when it comes the focus rs and I see your only in Middlesex.
If 550 is your goal I’d get a 550 rated turbo now and just run it at lower power rather than going for 460 now then having to change turbos further down the line
Cheers Paul
Cheers Paul
7670 efr does 630bhp or More on cossie. Mark has run 530 on 7064.
Is the RS 2.5 l? If so would prob need the 7670
Is there a lot of people running efr’s on the focus’s?
Don’t think I’ve actually seen one yet...
Seen a lot on precision turbos
Cheers Paul
Cheers Paul
Jonfoc went out in one with the smaller version of my turbo and he was shocked by how fast it came on boost.
My 2.2 stroker will spin up my 7064....in Mark Shead’s words “like electric”
I am prob going itb on my stroker 2.2 cossie, I had my cos 205 back from mark in low boost and it broke the gear box, when I put the new box on I could not believe how brutal high boost was in my little 205...I am actually a little fearful of how it will be on the new motor.
PF's Guitar God!!!
Spoke to Ben at Jamsport. He highly recommended a EFR7163. Said it has a much better spool than the EFR7064 on the 5 cylinder engines.
Waiting to hear back from Devil Developments.
That might work out, I think 800bhp tried it on a cossie and didn't work.
Sonic Boom
92
06-08-2014 10:16 AM
JonnyBravo
05-01-2012 07:34 PM
