2wd Saph, Head Issue?
Hi all,
just changed head gasket on 2wd saph. Had coolant in number 2 cylinder. Started car and still running on 3/missing,took plugs out, coolant still dripping onto piston. Just need a bit of advice and possible cause. Going to take head off again this morning. Anything obvious i should be looking for.
Any help greatly appreciated,
cheers Steve
cheers Steve
I wonder if the block has a crack? Have you seen the cheap 205 bottom end for sale on here today? Might be worth grabbing it quick just in case and flog it on if not needed?
fozzy70 (25-02-2018)
Thanks for the reply. Block looks ok, have stripped the head, going to get it crack tested. Usual corrosion around water ways but looks ok on the outside lol
Steve
Steve
New Owner
If its an old head and the coolant has not been changed regularly could have succumbed to corrosion and eventually head failure. As Ridgey says pressure test will tell.
Make sure sure you check the full length of the bores for hairlined cracks, see loads go like that
Cheers Paul
Cheers Paul
Thanks for your replies, stripped head this morning, off to be tested on monday. if it is cracked can it be repaired? or just bin it?, or a nice paperweight lol
Yes you can have your water ways tig welded I’ve had my water ways repaired due to mild corrosion
Been thinking about this most of today. forgive the ignorance but what would i need to change to replace my 2wd for a 4x4 head? I know 4x4 pistons are different, which raises compression?, By how much?. Thermostat housing different?, anything else i would need to change? I am thinking worst case if my head is cracked and cannot find a good 2wd one.
Cheers for all your help
Steve
Steve
Why don’t you just drop the head off at a good machine shop for repair and check condition of the valve guides while your at it?
Post it to ht Howard in slough
Thanks for the reply's guys, had head pressure checked, all good! phew, having a skim tomorrow. Have found a crack in bore number 2 as Caddyshack mentioned. What would be the best way to go with this? Liner?,New block?, Any thoughts or advice would be appreciated. While its in bits i was thinking about bearings etc etc, should i replace or leave alone?
Steev
Steev
Can you liner a 205 block?
Yes you can liner a 205 but this may be more feesable...
https://rover.ebay.com/rover/0/0/0?m...2F292433148030
Defo worth getting your crank checked as that will answer your question about your bearings
Must just be your luck I know of one running 460 that gets abused hard and block is holding up okay lol
Location: it's not where you are, it's where you've been and where you hope to be
you can liner the block but its not really a good idea if you're planning a liner for a cracked bore and use the other three without a full 4 cylinder rebore to next size up
Would a 2nd hand 200 block be better and sell on the 205
Cheers for all replys so far, appreciate it.
Right so this is where i am atm.
I am going to get engine out tomorrow eve. I have no idea if the pistons are std or o/size? If standard i was thinking of having a liner fitted then new rings. If its already been bored then i was thinking of another 205 block thats std and having bored to 0.5 if needed, depending on condition of bores etc. I think a 200 block plus parts etc etc will be too much. I have never ran more than 300bhp, its only 260ish atm so a 205 is more than adequate for me.
Any thoughts to that idea that doesn't involve a 200 block?
steve
steve
Engine out, pistons are 1.00 o/size. Not really what i wanted to find, i would of preferred 0.5 o/size. If i get another block, bore it to 0.5, get new 0.5 pistons, will i have to have valve cut outs machined into pistons as mine is 2wd? or can i just put them in as is?
Steve
Steve
Steve
Steve
I run a low comp set up and have Mahle pistons with valve cut-outs.
Always better having cut outs as even on standard cams the valves can touch the pistons so if your heads been skimmed you’ll want an extra bit of clearance.
+1mm will be absolutely fine with 300bhp
thanks for your replys, I am looking for another 205 block. If i can find one with good std bores then all well and good, if not then i will go to 0.50 o/s. I have just got a full engine gasket set with group a gasket, will give the crank and bearings a good going over as all i wanted to do other night was check piston size. Anyone who has, or knows of a decent 205 block please let me know. I am willing to collect or if its too far away am happy to pay for shipping.
Thanks again for your replys
Steve
Steve
Steve
Steve
Many thanks to all those who took the time to help me with my questions. I have got another block(arrived today), its on a std bore, i have measure it at 90.84. I plan on having it bored to 0.5 o/size, new pistons, new mains, big ends and small end bushes while its apart. Hopefully will be able to get it all done by mid april, so will get some use in the summer. Just another question with regards to running in. I have read conflicting articles, some say take it easy varying the revs for 1000miles, whilst others say take it easy for a few hundred, change oil then use as normal? any help or advice would be greatly appreciated.
Steve
Steve
Steve
Steve
" When I ran my new engine in I restricted revs to no more than 3000 did'nt labour it up hills and it worked fine. Changed oil and filter after first 300 miles and again at 1000 miles.Even at just 3000 revs it was happy doing 85 to 90mph so not real slow.
No doubt there will be lots of others who will have there own ideas. Do what ever you feel comfortable with.
fozzy70 (10-03-2018)
Running in a newly built engine is one of those things that there will be various advice on what is best.
I have completely stripped the old engine this morning. Should have new pistons by tue, so i can get them off with block to be bored and cleaned. I have ordered new bearings and oil pump while its apart as dont wanna be replacing the oil pump if it fails in a few months lol.
Cheers for your advice, much appreciated
It doesn't take 1000miles to run in an engine imo
I ran my engine in on a standard mineral oil for 200/250 miles and even that was too many miles ,
just normal driving , boosting it now and again , obviously not revving the piss outa it , changed oil and then went straight onto the rollers and mapped , that was 5/6 years ago and engine has been perfect
As said everyone has there own ways of doing it ,but some folk take running in an engine to unnecessary extreme's the things they do lol
I was always taught to run in for 1000 miles from
The date I started my apprenticeship 21 years ago but it's been so many years that I've had to rebuild an engine due to always changing whole engines these days as cheaper/quicker that oil and tech may have moved on by now and not needed? If I was rebuilding an engine now I'd personally run in for 1000 miles
Still but I'm not an engine builder for a job so they may not. Can't do it any harm
All I can say on this post is I hope you didn't pay £400 for a 205 block as at the end of the day they are only a old pinto block yes the price is going up on them they was £50 all day long there now £150 / £200 for one . Iv got a chap that I had 4. 205 blocks off now . Every time he gets one I just by it off him as there only going up in price i pay him £100
Didn't pay anywhere near that for the block. Got a 205 block, 2322 stamped by dizzy, is newer than my old one by 6 months, slight wear but on a std bore, £120 delivered
