How can I find out what size master cylinders I need?
I've fitted a pedal box to the focus. My trouble is I've no idea what size master cylinders to use. My brakes are all Alcon with 4 pistons on the front and 2 on the rear. Then there's the clutch, I'm using the standard slave cylinder. On the Ford pedals the cylinder says 19.05.
Any help would be greatly appreciated
Jon
Jon
I believe this is quite a science as it also has calcs due to pedal throw and leverage. Alcon may be able to advise you where to start but it might be a bit trial and error.
The rear on my old bias pedal box has a different size to the front. Do you have any yet? I have 2 on my pedal box that you can try if you want? Mine is a comp brake setup and worked ok on my Cossie brakes.
I will look at the sizes that I have, I think they are decent Tipton units. You can then fine tune from there.
jonfoc (17-01-2018)
Martin has replied in seconds.
Toby I've been advised to go with .625 and .7. If you've got these sizes I can try that would be great. It'll save me a few quid if I need to go up or down
Pretty sure they are the exact ones. Text me on Saturday / sunday if I forget to let you know tomoz
jonfoc (19-01-2018)
jonfoc (19-01-2018)
I am sending Jon my AP ones to try.
jonfoc (19-01-2018)
@Mark how do you workout the ratio?
If the pedal was 200mm long (piviot to pedal end) then the distance from pivot to clevis was 100mm then you would have a 2:1 ratio. (Almost impossible to stop the car lol)
Pivot to clevis at 50mm would be 4:1.
You got it?
This what I have in mine - brakes are really responsive, no more effort than in a servo assisted car.
http://www.wilwood.com/Pedals/PedalP...emno=340-15074
Sonic Boom
13-03-2014 12:21 AM
L33 BYT
14-02-2005 08:33 PM
