help! does the ford focus rs mk1 turbo engine have same mounting points
Old 04-01-2018, 12:34 PM
turbo2015
turbo2015's Avatar
Default help! does the ford focus rs mk1 turbo engine have same mounting points
Thanks again
need you heads.
Plan is to drop the rs gearbox and engine into my kit car, which currently has the 2.0 zetec blacktop+ IB5 gearbox
Nearly done a deal on the rs focus mk1 engine.
Needed to know if the mk1 rs focus engine has the same mounting points as the 2.0 zetec blacktop engine. and if the focus rs gearbox will have the same mounting points as my current IB5 gearbox.
fwd and rwd engines, whats the difference. if any.
Thanks Again
Old 04-01-2018, 01:42 PM
turbo2015
turbo2015's Avatar
thanks just spoke to a mate in a tuning garage, its the same engine turned around. has teh same engine mount points. gear box mounts are different on the IB5 and Focus RS and thats now my hurdle, hate to start to chop the kit car chassis to make the MT75 fit.
Old 04-01-2018, 04:39 PM
bigdel
bigdel's Avatar
Focus RS mounts on the gearbox side using a large ally bracket bolted to the top of the box. The bracket has a large threaded bolt on the top that goes through the mount, which in turn is mounted to the bracket that would normally support the charge cooler
You can see it on the right in this pic, although this one will have an A2A intercooler instead of the standard chargecooler.
Old 04-01-2018, 05:31 PM
big_wasa
big_wasa's Avatar
It’s the same engine mount. You can use what ever is in the rocket.
The engine is oriantated exactly the same as every Focus.
If you have the classic rocket then ib5, mtx75 and the Getrag 6 speed have all been fitted.
Gearbox mounts are differant but they mount to the same place in the Focus.
Old 04-01-2018, 08:39 PM
james kiely
james kiely's Avatar
you could get some custom mounts off gary [crazycage]
i bought the 3 i needed off him £195 one engine and 2 gearbox .im sure these would be modded to weld to your chassis easier than trying to use the ford mount
mine were for a mk3/4 escort
steve.rst
18-11-2014 05:16 PM
Ginge !
25-02-2006 07:36 PM
M K
15
29-12-2005 05:17 PM
Quick Reply: help! does the ford focus rs mk1 turbo engine have same mounting points
