View Full Version : General Car Related Discussion.
- 3dr generall info required please
- Antother ava orniment that ammounted to nothing read this
- Cosworth/ Focus Heated front screens? Help
- pro loy 500 cooler and rad, need paint advice
- Compbrake TCA's
- Nice garage..
- FRS Brembo caliper brackets to 2wd Cossie hub - where from?
- Fiesta ST Opinions
- reyland
- TDCI 6 speed onto escort td engine anybody know
- Inlet manifolds
- Carbon fiber sunroof blank
- Mk3 mondeo master cylinder issues
- poor mpg focus mk1
- 307 hdi running issues???
- gear linkage repair kit
- courier for a roll cage any ideas ?
- Crashed cossie on ebay
- 1/4 npt with 15mm outlet brass facet pump fitting
- ITB's and a turbo..
- Dent erasers in the North East.
- 3 spoke rs steering wheel
- gti skirts
- Help naming these wheels
- Saph Rollcage in a 3Dr?
- best mk1 focus handling mods?
- bodywork repairs/painting in hampshire?
- Chip will not allow full boost
- Focus radiator drain plug?
- need a new car any suggestions
- injectors and megasquirt
- photo as promised
- Megane 1.4 - Petrol - 56 plate - what to look for? (urgent)
- Finally back in a ford Wooo wooooooo
- Wrc breather
- Brembo conversion plates
- Best Ever Drivers Car...?
- Panther black Fords
- Kasabian re wired , escort cozzy
- duratec 2.5 swop
- What the hell is this?
- Machinists/Designers your view on this
- what gear is normally used on a 2wd cosworth for a power run..?
- don't complain about the cost of performance parts for your car
- Massive thumbs up for Will Pedley Racing!
- Any meets ??
- help! please
- Bargain of the day..tyre profiles?
- mk3 1.1 to zetec wiring help ?
- whos going to flame and thunder at pod this weekend
- Any one tried these guages and r they any good
- gear box rebuild question
- gaz vs avo coilovers
- you think these gauges over priced
- body kits for escort van
- part trouble
- ford ka zetec project HELP plz any 1
- buckled rim repair
- Starting another ,lol
- What thread
- ATL CELL vent
- Saff Cosworth track rods - what's the difference?
- Where can i get cosworth 4x4 front outer cv circlips? pics included
- Joe at gs motorsport
- Cosworth Switch Panels
- dipstick insert
- Drive way finds,
- extra security- cut of switches
- Snap on tools.
- Mk1 frs duratec into escort s2 rst. Will it fit ?
- auto to manual conversion??
- Head gasket question
- is this etch primer any good ?
- another whats it worth. brand new 4x4 cosworth engine loom
- Strange Starting Issue, MK1 Focus
- Anyone know what these wheels are
- privet reg removel, no tax or mot. cant it be done?
- mk2 escort is this cheap[nothing to do with me ]
- mk6 escy bitch to start
- any one have a bonnet bra for there saph
- P8 L8 ecu
- cosworth inlet on cvh
- dmb gel badges
- Mondeo MOT fail help.....
- Awsome car from the past
- gas cylinder
- Ford Ranger Buying Advice
- EGR Valve Blanking Plate
- newby with new van
- best place to get an ecu and mapped??
- Who maps megasquirt management ??!
- 1.8 zetec turbo issues
- escort rs turbo front badge colour
- fuel hose question!
- Ford Transit County 4x4's
- Private Number plate Spacing
- Zetec engine
- love the car, but hate the grill
- cosworth oil breather set up ?
- Engine experts: Strange one - piston slap after a few hundred miles?
- Mondeo 4x4 how many made??
- Matt lewis
- getting into rallying
- some advice
- Mk3 Focus Bonnet Won't Open
- worst chavved up jaguar
- Clutches
- Where to look next? Rear window heating element failed?
- Zvh xr3i?
- Cossie Engined XR2 for sale on gumtree
- fact or fiction, MOT certificates
- Turbo dampner help
- Can 2WD and 4x4 ABS parts be mixed ?
- Audi RS6 intercoolers - where?
- water leak
- zetec engine connecting rod length
- power
- Comp MOs for £300!
- What hot hatch for around £3k/£3500k
- Focus RS Brembo's
- Removing and refitting 2001 mk3 mondeo steering wheel?
- 4 spoke steering wheel
- Handbrake shoes and cables
- cosworth 2wd propshaft shims
- blue smoke
- what is a erst s1 shell worth these days? i know for one and want it
- what do we think of this
- Big thank you to Mark @ MK
- J318ajn anyone know this rs2000?
- saph pluss trailer, being pulled by a s reg merc e300
- any vaux techs
- Sierra fuel sender
- Remote locks on a Sierra?
- Ford Nuts/Bolts do you have to use specific ones?
- Can you MOT a car with no reverse?
- spoilers
- Cps
- Getting tucked up after a crash?
- cosworth vs XR4x4 diff ratio
- Winter tyres
- where can i buy a new pfo9, cos tps
- Best insurers for agreed values?
- Rs turbo cps
- bbc1 right now!!!!!!
- How much fuel can you store on private property
- mtx conversion (focus rs)
- revotec `fan switch
- log books
- Random fiat question!
- sapphire cosworth covers
- talking about old car mags...
- Michael Rainbird! Revs 1999
- any ford meets coming up in essex
- Ford Mag Question
- Heater on my Ford Focus Zetec (Reg 07)
- IB5 Gearbox Weight?
- cosworth 4x4 clutch cables
- Mtx gearbox ratios advice needed!
- gearbox oil cooler
- hart inlet / small turbo t/body whos done it?
- New style MOT's
- anyone seen...
- Engine block shredder
- Storing a cosworth over winter
- V6 exhaust
- i bet this guy was heavily clenched!
- Dan Wheldon killed in Indy Car crash!!!
- Quick valuation on this guys,cat d 57 plate,5000 mile Ka.
- matching front an drear diff ratios
- Anyone know the history of this fiesta xr2 ????
- spa oil pressure gauge problem
- xr2 shell
- Anyone got a stolen escort MK1 Mexico they would like to ring?
- Mk6 Fiesta Carbon door cards
- Short term insurance help
- S Max Titanium Sport X 240PS
- P8 question
- boot mounted intercooler
- escort mk 4 slam panel. where from?? pig to weld on??
- 1800 cvh question ?
- Series 2 RS Turbo
- Seized bolts/focus rear wishbones :@
- missing brake pipe
- Gt3076r v t34
- What amp fuse to use for a fuel pump?
- what mods needed
- BBR DBF38???????
- mk4 cabby into pick
- Early escort mk3 strut brace
- Mk6 escort gearbox
- escos running rough
- can someone explain how the 2 tank breathers set up works ?
- BTCC on ITV4 @ Silverstone Final Round
- Cleaning up/painting exhaust manifold.....any suggestions on what to use?
- Been looking at Audi's, what does s line give you?
- cheap drive shafts
- too much time on his hands
- escort rs turbo
- Ebay tossers...
- Will my saff cossie do 200mph????
- turbo 10.25- 1 comp engine ?
- Does anyone make GRP Cosworth front wings?
- Standard Xr3i Springs
- whats the plate called that goes inbtween engine block and gear box ?
- Puma
- Anyone know j440sbw
- Gatebill
- HELP! omex 600 starting- racing sunday car wont start! advice please
- how do i get my ipod touch to work through
- Is this legal?
- where can i get
- air filter location
- st170 engine into mk4 escort
- Cannonball run on 5US
- Peugeot 106 cosworth 4x4 wrc
- Cosworth Standard Springs??
- what's the worst job youv'e done on your car
- could someone help please
- Piggy back ecu for z-turbo
- Which is the best match silver for painting ford alloys...
- empty caulking tubes
- focus 2.0 turbo rs wrc rally car
- Transit connect mpg???
- How to identify manifold flange ?
- Educational oil change video
- restore
- ever wondered...............
- Anti freeze
- Need some trailer help please, braking.
- bm 316 compact abs pump
- xr2 opinions and ruff price
- Anyone help me spraying?!
- Mondeo mk3 diagnostic plug location?
- Focus RS anyone know this car?
- Thanks to power engineering
- Any vw techs that can help?
- carburettor people? help needed please?
- Wing mirrors
- Possible over fuelling
- Any Forza 4 threads??
- FAO anyone who has done the facelight focus headlight upgrade! :@
- hillingdon motor company
- washer jets
- can group a wheel inserts be knocked out and if so,how ?
- Escort zetec silvertop waterpump ribbed pulley?
- is this a bad idea to be thinking ?
- Tyres
- 6000cd compatible with mondeo 08
- FAO :Si B , New conversion for your evo idea !!!
