View Full Version : General Car Related Discussion.
- Biting the bullet
- recaro seat clips
- Pair of T28 turbos
- Mk1 Sierra Windscreen Rubber Trim
- OE L8 ECU + WS board...what would it be worth..?
- What is the correct tint for a 3dr Cosworth windscreen
- Cylinder heads
- Where to buy glass for cars?
- Solar powered trickle battery charger
- for anyone running Boostmonkeys OFAM ECU
- Escort van 1.8td wont start weird problem
- People in the know about coilovers and spring rating plz help
- Grp A 500s live streaming on Drivetribe (Facebook)
- BINKY 15
- SMax 2.0l TDI wont run
- Capri 2.8i - what's a special???
- Anyone in the bucks area any good with CVH's
- Where to get body repair panels sapphire cosworth
- Ignition amp mounting
- early s2 seat material name please
- 88spec clocks and 90spec rs turbo
- alternator
- Mk 4 xr3i. Puma 1.7 conversion.
- Big wing sump, where to!!!
- Info needed powershift gearbox
- St170 vs zetec 2.0 vs 1.8
- turbo charger
- Sapp Cossie 4wd rear lights/plate surround and front indys...what are they worth?
- Hose clamp on dump valve
- Best Products for Magnum Grey?
- RX8 engine swaps? Audi 20V turbo - how hard? Martoon?
- running turbo oil feed from sandwich plate ok?
- 4x4 cosworth starter motor
- Advice on turbo oil feed Ford Focus pos
- Stack custom dash complete
- FAO Lacey
- Dark blue Mk3 focus st stolen.... MT63 DZY
- Water in transit locks
- Cosworth 7.5 diff drive shaft lengths
- Turbo oil feed, so is this really the right pipe then ? (update)
- Escort Cosworth 400LPH high Flow Fuel pump - Fit to Fiesta RS Turbo
- Private plates
- Anyone got a spare 24v boa cosworth?
- Show me which is beautiful - Escort mk2
- rolling road question
- Legend vehicle specialists - instagram / twitter
- Poor starting from cold/no throttle response
- Cosworth fly wheel light or Heavy
- Ford Focus 2003 head unit query
- Is it possible that a car can be fitted with the wrong turbo ?
- HELP, suspension pro please
- breaking my project advise needed
- New Top Gear thread
- how much suspension droop minimum
- Turbo oil feed pipe NIGHTMARE (had to abandon car 17 miles away) !!
- Siemens 83Ib 3105 injectors ?
- Which ECU Emerald K6, Omex 600, stinger etc
- 4x4 Haldex system
- Who does Rwd conversions
- Mappers north of England
- 500+bhp Cosworth engine advice please.
- fiesta st mk6 smoking!?
- Custom stack dash
- Gaz coil overs rubbing chassis,
- Peugeot/Citroen bought Vauxhall.
- Fifth injector kits still available
- Can i trust these guys for bodywork repair on my Ford Fiesta 2001 mk5
- xr2 mk2 fiesta tie bar required drivers side
- Ribbed belt tensioner..
- escort cosworth hex interior
- Ford Focus ST MK2 Gurus
- What lambda control unit to buy?
- Antifreeze photo (premixed or concentrated ? )
- Is this antifreeze compatible with steal seal ?
- Ford after market car stereo
- Boost monkeys
- overheating problem
- Ford Fiesta Style 1.4 2007 MK5 heater blower switch 123 not working! help!
- How old is too old for track days?
- GTX2860r gen 2 turbo
- St2 facelift any problems to look for?
- Recaro mondeo mk3
- B23 gty
- DPE Engineering
- How to use steel seal, head gasket repair ?
- Ford forcus water solenoid valve
- Fitting Transit connect starters to cossie.
- Even better value than £30k golf
- Escort rs turbo mfi
- Cosworth wasted spark kit
- Dmf failure time span.
- Sapphire door weather strip
- Scorpio Cosworth air conditioning
- Sierra cosworth power output
- Fiesta RS Turbo J734 GTP on Ebay
- 2011 transit connect transmission replacement
- Mk5 1.25 fiesta no interior lights (dash, heater controls)
- St170 Correct Spark Plugs
- Turbo rebuilt prices
- Lovely day for Engine bay Spring clean
- Pug 207 coolant leak
- Mk1 FRS crank position sensor
- At last
- Best track car for around £1500 or less
- J888 CYA Fiesta Rs Turbo
- Finally rally ready !
- Clutch for rs2000 4x4
- 4wd abs loom ecu sensors to 2wd sierra
- Recommend me someone to finish putting my car back together please
- Hydraulic clutch.
- 21w sidelight bulbs replaced with indicators??
- Mk 2 Focus indicators
- Focus ST250 2.0l ecoboost service schedule?
- weekend fun car £12000-£14000.....?
- Underbody seam sealer query??
- Ford ST Focus side exhaust exit........
- Fiesta ST smashed up at Ford fair
- Mondeo st diesel pump
- Back end stepping out without provocation [Lexus, not Ford]
- I've agreed to repair a friend's car, but I'm unsure on a quote to give him, can you
- Does anyone know this Flint Grey Saff? G979 TRC
- Cars bought for cash, Scrap cars wanted etc... How do these guys make money?...
- Ford FIESTA RS1800 MK3 gearbox
- Ford Fiesta 1.4 tdci ford technitions ?
- Can anyone help I also need a mk1 mondeo servo and master
- Bloody Hyundai accent's back..
- Ford vv carb parts suppliers? ?? Help please
- Bumper coloured stripe measurement?
- Correct offset for 17's on a 3 door COSWORTH
- Quoted £400 for replacement head gasket inc parts, should I be wary ? is it to cheap?
- 2007 Fiesta ST. 2 owners, 70k. Leather interior
- Cosworth block linners ?
- Ford Kuga rear coil springs
- Hpi checks, who to use?
- Sapph 2wd focus RS rims what tyre size?
- Side exit exhaust question
- Can anyone ID this key?
- US YB owners.
- cosworth idle control mod for anti lag?
- Cheap Brake Upgrade?
- saff 2wd spliter
- Ford part number help - is this a 3 door Cosworth part ?
- can't see any pictures on here?
- Getting my car back on the road after being stripped for 5-6yrs, what should I do 1st
- Getting my car back on the road after sitting for 5-6yrs.... what do I need to change
- What MPG is this?
- Would you own a smiley face transit now?
- Cooling system issues still?
- Cheap escort rs turbo
- BMW E60 520d cutting out issue - strange one???
- Fiesta RS 1800 Gearbox
- F'ing Turbo oil feed pipe
- MK1 FRS CAMS Vs 2.0 Blk TOP Differences
- m.o.t tester from hell longrock mot near penzance
- 2007 fiesta tdci lighting
- Sapphire headlight differences
- Bilstein group a suspension
- Sync GPS and DAB issues, 62 plate Focus ST250
- Mk4 Escort Scoobie
- Bumper trim.?
- Cosworth 2wd t5 measurements
- i got one for you all
- Focus Deisel engine blow up?
- Who's into offroading/green laning?
- 2003 Ford Focus automatic, headscratcher
- Track car hand held fire extinguisher recommendations?
- look what i brought for fun LOL
- Look what I found!
- Best process for redoing underside of car?
- clutch for 550/450 yb
- Will an escos strut brace fit a 3dr?
- Fast ford this month ICS rs500 rep
- Escort mk6 van
- Fiesta st150, any good?
- tdci damaged piston? Short Vid. What u fink
- AEM Inline External High Flow Fuel Pump 380LPH #50-1005
- pug 207 cc?
- black-top zetec engine mount in a mk.5 escort
- Cosworth YB 500 BHP compression
- Rs turbo
- S1 turbo brake upgrade.
- Engine bay clips.
- m o t tester from hell
- Ford ranger 3.2 2015
- passiontechnicians....... lets talk diagnostics
- Sleepers - Bet this ones a giggle. Show us yours
- Ctek battery charger not working?
- Mk6 transit fwd failed headgasket?
- 200 block long studs
- Wanted H13 arb 3dr
- MK1 Focus inner driveshaft joints
- the dojj fast ford mag review, yes, another one
- Alarm installer south wales
- One for all you XR fans - an XR50!
- So Bernie got booted
- This makes the £25k golf look sensible.....
- Logbook dilemma
- Diagnostic laptop
- So... bad news and good news...
- supra diff fitting kit & rear cover (where from?)
- Idiots in the fog!
- New mot rules being discussed in government
- New road tax???
- Anyone clued up on vw pd engines? Any vw techs?
- What would you call this stereo panel??
- Flocking, who to use?
- Wots needed for a 500Bhp YB motor
- Where to get boost hose when fitting a hart inlet to cosworth?
- transit connect 2006 tddi engine me thinks
- Stolen moonstone 4x4 sapphire stolen
- Free mileage /mot info
- Fiesta MK3 arches
- Vibration only when accelerating?
- 2017 Car Tax
- 3dr antiroll bar
- Hamilton has won the 2017 championship
- Ford Focus 2.0 tdci help please!
- MK1 FRS Valve SPRING ID?
- Where can I get a Mk1 Astra 4 door fuel tank??
- Please help !!!!Fiesta rs turbo ofab wont start no injector pulse on cranking
- Sierra Cosworth 3dr side skirts
- Ford Sierra Not engaging gears?
- Fuse box
- mercedes wheel bearings.....
- 2003 Mk 6 2.4 tdci Transit stopped running can't restart.
- Efi rs turbo engine into ford Orion!
- What strut Brace for 3dr track car?
- t5 upgrade
- BMW remap??
- Focus 53 Plate TDCI Sport
- JK12 Jamie Knowles R.I.P of Passionford
- Anyone used SPL? surface processing.
- Anyone reccomend somewhere to get Zinc Plating done?
- Cosworth head sizes / minimum
- Heads up for anyone using Anglia car auctions
- Megasquirt tuners in the North East
- Carbon comp centre caps
- Celica gt 4wd st185
- Mk2.5 Focus bonnet catch broke - how to open bonnet?
- Welding a damaged exhaust housing
- Water, air sensor Brands Hatch performance
- Any Mk2 Focus ST engine converted sierras?
- F-150 4.9 l mfi
- sapp/3door cossie steering wheel ford badge
- Please delete
- whats the best not over priced spark plugs
- Register of Mk1 and Mk2 Fiestas
- Bonnet straps
- HT rubber inlet bracket
