Antifreeze photo (premixed or concentrated ? )
is this antifreeze pre mixed or concentrated ?
thanks
thanks
having a mid life crisis
Ready mix as in probaly ready too mix with water!!!!!!!!!!!!!
If in doubt go back to the place you bought it from and ask for anti freeze you can dilute!!!!!!
so do you think it already has water in or are you suggesting that it needs mixing with water ? if not sure is it ok ot just app tap water to it ?
well as said I am adding a pour in thing to the coolant which is Ł30 a bottle, on the bottle steal seal reads not compatible with water-less antifreeze so I want to make sure if this is water-less or not.
I posted a pic for ray barker as he requested in pm, cannot post pic there so made this thread for him to see the pic,
so would adding tap water be ok including hwen adding steal seal into the equeation ?
If you car is leaking and losing water then using steal seal will be a temp fix and as people have said already may do more harm than good, and if not compatible with waterless coolant then you just risking more damage.
Get the head gasket done then it takes away the worry
burnzy
There is only 1 company I know of that make waterless coolant and your probably not going to get your hands on it.
That is a normal coolant and is fine with steal seal, stop asking questions about it please.
It's also ready mixed so it is concentrate with water added, concentrated antifreeze is still not waterless coolant, it's a completely different special type of coolant you have to specifically buy.
as said, spent Ł2000 on repairs on this in less than 2 years, I would get head gasket replaced if I know it needs doing but there are other potential other big problems as well and when I weigh it all up I winder if repalcing the hg would be worth it. the car runs great other than having to top up water time-time.
I have 6 bottles which = 6 litres, will that be enough ?
reads ready mixed which I assume refers ot antifreeze and coolant.
main ingredients Mono Ethylene Glcol
jut pour it in it be okay as it pre mixed. and when it runs low top up with tap water as when required
but if it not compatible with steal seal just take it back and buy normal anti freeze that is suitable with steal seal and the again top up with water as and when required, go to a motor factors as they will be able to point you to the right solution
Proper water less anti coolant is a an expensive product I think around Ł100+ mark and will not say anti freeze as people have said is totally different type of productr and only available form specialist places.
See people try and help you and then you argue with them can you not see people find this annoying
steal seal says on bottle not compatible with waterless coolants or pure antifreeze, if this bottle does contain water then isn't this normal anti freeze ?
so is this normal anti freeze then ? just reads antifreeze & coolant but does not read water.
and I do appreciete people helping me, especially tonight I feel people have been very helpful tonight and I do appreciate that so thank you
Omg
its READY MIX it means it's already been mixed (with water) to save you the time if mixing it yourself from a concentrated form.
End of no more questions required on the matter
Waterless coolant is made and marketed by a company called Evans.
Before use, the waterless coolant requires all traces of traditional water based antifreeze coolant to be removed from the engine cooling system by means of a special flushing fluid.
To flush and top up your car with the waterless coolant would cost you in the region of Ł150+. Any subseqeunt top ups once that substance has been added will be with the special waterless coolant and NOT water or pre-mixed coolant or "ezeerF itnA" (which you have in your hand in your photo)
DO NOT confuse ready mixed (ready to use) or concentrate (dilute with water before use) with a waterless coolant. Surely you're familiar with orange squash???
I'm quite a tolerant person and will give the benefit of the doubt to most of people but I must admit that you're persistent daft questions really are starting to grate.
Everything you have asked (with the exception of a bit of advice with that oil feed pipe which you ignored anyway) could have been answered by a simple google or just by reading the instructions on the product you've purchased.
FastLife91 When are you going to wake up and get rid of your Focus!!! If you have REALLY had this many ongoing problems with it week after week surely you can see its had its day!!!! Do you not want a car that is reliable and all you will have to do is clean it and service it as required and not have to be asking us every day how to fix it!!!!
The following 5 users liked this post by Martin-Hadland:
155lee (03-03-2017),
FastLife91 (03-03-2017),
focusv8 (04-03-2017),
haz87 (03-03-2017),
nixon_2wd (03-03-2017)
Originally Posted by RichieST
That's the wrong stuff anyway, should be the pink stuff for a focus, that stuff will react with the pink thats in there, sludge up and block the system.
When you take it back to halfords, do everyone a favour and buy a bicycle.
not got the pink stuff in there, just tapwater
Are you being serious? Do you think that your Focus is unique and does not require anti-freeze like every other vehicle in Britain does? Yours just has tap water in it? If that is the case you are extremely lucky the block has not frozen and split!!!!! Get real!!!!!!!!!!!
My wife asked me why I had been staring at a bottle for an hour....I explained that it clearly had "concentrate" written on it.
It has not been tool cold at all this winter, been unusually warm and no way the block would freeze in such humid conditions !! :rtf m:
Quote of the fucking centenary!
You do realise without anti-freeze your engine's coolant system is building up rust deposits which could lead a to blocked radiator or matrix. Anti-freeze keeps the coolant system clean and lubricated. Worth a thought.
that is why I am asking where about the drain plug on the radiator so I can flush my coolant and refill !
Where abouts are you from?
You have got to be winding me up as its such a basic requirement for a car engine along with oil, clutch and brake fluid!!!!!!!!
