2011 transit connect transmission replacement
Hi, I have a 2011 transit connect 2.0L automatic transmission needs replacement. I have an automatic from a 2006 focus 2.0. Now i've been told this should be exactly the same. Does anyone know if it is plug and play? Or is there any wiring work to be done?
Thanks.
Thanks.
Received 1,042 Likes
I dont see why not. Ive only ever removed manual gearboxes from transit connects. Some people remove the sub frame. I just use a vehicle sissor jack and put between the sub frame and engine and wind the jack out so it pushes the engine across so you can get the gearbox out.
