Cosworth YB 500 BHP compression
As some of you might no I'm planning on putting together a 500 BHP yb motor . Well iv been looking at some wossner Pistons on ebay that all ready have pockets it them and they go up in .25 sizes and have a compression of 8.1
but as iv never looked into this stuff before iv not got a clue . I will be using a twin scroll turbo when the time comes .
Have any of you got any forts on this
I understood they would be all standard comp now.
ive heard bad reports on here from guys usings wossner pistons on a yb
apparently they are bad for piston slap, but id have thought that would be down to the block not machined correctly
I know of plenty of jap cars running wossners in drift cars etc and having no problems
I saw recently a company on facebook advertising a remake of the original mahle pistons with valve cutouts already in them ,
I have a look to see if I can find there name
Certainly no reason to go very low, but depending on the above you could go into the 9's
Mid 8's is very safe though these days for most engines around that power.
I once read someone describe Wossners sounding like a skeleton having a wank in a biscuit tin.
Its the torque curve you should be focused on, not top end bhp. With the new turbosystems, early boost and volumetric efficiency around 4000rpm means you need to lower the compression ratio to get optimum ignition angle to avoid knock (due to the stoneage sparkplug center ignition system).
Wish we had turbulent jet ignition (TJI) for the YB
Pretty much every 16v head in existence has the plug in the middle, a very good place for it all things considered.
Didnt his engine let go though?
Cheers Paul
Cheers Paul
I know Cossie Dave is on 700bhp but unsure of the comp ratio...there is a huge difference in a 500bhp engine and a 700 one...as in going from 300 to 400bhp isnt a biggy but pushing past 600 to 700 is pushing the boundaries of so many more factors, there will be far more engine faliures on a 700 engine than on a 500 one.
Hi mate my 200 block has new cosworth pocketed pistons and shot peened rods comming out as im re speccing maybe perfect will have to check size
And i dont know his comp ratio obviously
Cheers Paul
Are you sticking with standard CC on the alloy block, Dave? If so, is there a reason why you didn't go bigger capacity?
Was that a standard crank that bent? I assume the arrow is going in the new block?
Are you keeping the same head?
Caddyshack (02-02-2017)
I guess you found the limit of the standard crank then!
cossie fan (unluckerly)
What caused the crank to bend Dave?
Cheers Paul
Cheers Paul
What's standard comp?
8.1:1?
Cheers Paul
8.1:1?
Cheers Paul
turbotrev (02-02-2017)
Bit worrying knowing ones bent so close to your target? Its got me thinking
Out of interest would a lower compression engine be less strenuous on components like the crank, rods, block etc??
Cheers Paul
Cheers Paul
