General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
There's nothing wrong with G19 sumps, more than any other converted sumps out there, i've had mine for years now, same as mates and nothing wrong at all
Someone had an issue with the gated baffle, now it was nothing to do with the work of G19. The guy who eventually built the engine made it clear the sump had been plated on the inside so the baffle didn't fit correct resulting in parts breaking off and causing the issue.
I have one and have no issues at all, my mate has just rebuilt his old motor with the same gear and it's old and again everything surrounding those parts are perfect
Had my sump done by scs good job and they recommended using the original baffle not the gated type. I'd recommend heli coiling the sump plug while u have the sump off, went to change my oil today and the threads came out with the plug!
Andy Gallagher modified a 2wd sump in the same way to clear a front drive shaft so could be used in 4x4 format but with engine moved further back I wonder if the fabricator of that sump did the same?
