Gaz coil overs rubbing chassis,
On what car? Any pics.
I suspect you can add some adjustable top mounts and put the shock to suit....have you reset the geometry?
Escort S2, I have got gaz at rear with adjustable bars, they are set the same at both sides and camber looks about the same, although near side has 5mm plus gap and offside is about 1mm or less. It's booked in for alignment but it's not gona solve the problem as camber looks ok and same as other side, measuring the bars comes in at same size also
On the mrs s2 from memory the coilovers are the same distance away on both sides, im raising it for its m.o.t sometime in the week if they arent ill post back
So, you need to find what is out. Or find someone to measure everything.
Have a worry my chassis is twisted or something. Can't see what else it could be. Bother wheels look same camber and measure the same between bars, and tight on one side and 5mm space on other, only other components involved is stub axle
Get it on a decent laser alignment like hunter, check it is all where it should be and rule out the basics, they may well find the offending area.
