Cheap Brake Upgrade?
I've been quite unimpressed with the 278mm brakes on my MK3 Focus. It's currently needing front discs and pads after 50k so was looking to upgrade the front brakes to 300mm from the larger engined Focuses.
I've spent a few hours researching and it seems the MK3 Focus and MK2 Focus seem to use the same brakes bar the ST's. The 278mm and 300mm brakes use the same callipers and brake pads, seemingly the only difference is the disc and carrier.
I got a set of carriers and callipers from a 2007 Focus 1.8TDCi for £35. I'm hoping to just use the carriers and install larger discs. Maybe refurb the MK2 callipers and flog them with my original 278mm carriers to make a few quid back.
I was just wondering if anyone knew more than me, is there any reason why this wouldn't work? Is there something I'm overseeing?
Talk to Reyland but Brake upgrade and cheap do not often go hand in hand...unless you can find another brake set up from a breakers.
Sounds about right but you will possibly also need to enlarge the bolt holes in the hub from 10mm to 12mm to accept the larger bolts for the bigger carrier. It's not too hard to do though, I did it on my Fiesta.
You might find the brakes are better if you simply upgrade the pads and replace the discs, but keeping the same size as you already have.
Caddyshack (09-02-2017)
Callipers arrived today, they're off a 2006 Focus 1.8TDCi. They're exactly the same ATE callipers fitted to my 2015 Focus 1.5TDCi which is interesting. Hoping to just be able to fit 300mm carriers on with my currently fitted calliper for a cheap and cheerfull 300mm brake upgrade.
Is it worth going for Brembo Max drilled discs with EBC pads or stick to OEM?
Going to order a seal kit and sort out the second hand calipers before throwing them back on ebay!
I can confirm that the calipers are the same as what's fitted.
However me being me I can't just throw the carriers on with some larger discs and be done with it!
So I got some 300mm brakes off a MK2 Focus that had done 194k. I'll let the pictures do the talking.
The brakes were...
The brakes were...
- Stripped
- Sand Blasted (Aluminium Oxide)
- Soaked in Bilt Hamber Deox Gel
- Etch Primed
- Epoxy Primed
- Given 2 Coats Hammerite Smooth Gold
- Rebuilt With New Seals, Pistons & Goodrich Speed Bleed Nipples
So I now have these fitted!
I can confirm that the callipers are the same between the 278mm and 300mm brakes on the MK2 and MK3 Focus however the carriers are not! For starters the MK2 uses a 12mm bolt and the MK3 Focus uses a 14mm bolt. The carriers had to be drilled out and tapped to make them fit but they were hitting the disc so they had to have 5.5mm spacers installed between the hub and the carrier.
These are OEM spec pads with HEL performance hoses and there is a huge improvement in initial pedal feel. It's far less spongy and I keep almost putting myself through the windscreen.
