Ford forcus water solenoid valve
Old 27-02-2017, 10:07 AM
ricky
ricky's Avatar
Default Ford forcus water solenoid valve
Does any one knows what it does it far of the Heating system on a 55 plate forcus ghia petrol
Attached Thumbnails Ford forcus water solenoid valve-fb_img_1488193193028.jpg
Old 28-02-2017, 12:03 PM
ricky
ricky's Avatar
117 views and not one comment
Old 28-02-2017, 12:13 PM
wayne1001
wayne1001's Avatar
that means 117 people don't know what it is 😉
Old 28-02-2017, 12:37 PM
ProjectBobcat
ProjectBobcat's Avatar
To be honest I didn't understand what you'd written.
"Does any one knows what it does it far of the Heating system on a 55 plate forcus ghia petrol"
Old 28-02-2017, 12:52 PM
ricky
ricky's Avatar
Smile
OK let's take it from the top ,my mate just bought a forcus and he is saying that the heater is luke warm it doesn't get hot just warm
After further investigation notice that that valve as been by pass by the pervious owner,that's why I posted this to see if any one knows the
Purpose of this valve, might not of worded it correctly in the frist place
Old 28-02-2017, 12:54 PM
ricky
ricky's Avatar
My bad it should have said part of the Heating system
Old 28-02-2017, 01:33 PM
burnzy
burnzy
burnzy's Avatar
On other marques I've known then to fit solenoids on heating systems to feed the matrix.
Old 28-02-2017, 01:41 PM
ProjectBobcat
I dont know the answer to your question specifically, but usually a heater solenoid would be an electronically controlled method of restricting the water flow based on your heater dial setting. so if your heaters set to cold, it would close stopping the hot water flow from the cooling system going to the matrix. The Mk4 Fiesta/Ka/Puma had a unit that was prone to failure if this is the same type of thing.
Old 28-02-2017, 01:49 PM
pcbp97
pcbp97's Avatar
That is a coolant degas shut off valve and it does this.
The coolant degas shutoff valve is designed to stop the degas process during cold start. Shortly after the engine is started, the coolant degas shutoff valve will close and reduce the coolant flowing through the engine which will improve cold start fuel economy and warm up time of the coolant. When the coolant temperature has reached 80°C the valve will open and allow hot coolant to circulate through the coolant expansion tank.
Ricardo Gidon
22-09-2014 06:34 PM
Ricardo Gidon
Ford Mondeo Including ST
21-09-2014 08:46 PM
Quick Reply: Ford forcus water solenoid valve
