- Move Strut Tops or get Adjustable TCA's?
- Left hand drive 3 door cosworth
- 2001 Fiesta Flight 1.3
- Lithium battery
- Best and Fastest engine to put in mk6 escort hatchback
- Where do I stand with this trader?
- Skyline powered escort
- Mk1 Focus RS front mat - price!?!
- Compomotive mo5
- Identifying gearbox
- looking for a top notch car welder near junction 4 M25, kent!
- powder coating and zinc plating where ??
- 190e 2.5 16v
- Type 9 Boxes
- DIY Yellow Zinc Electroplating Setup.
- Best way to get a interior carpet delivered
- Advice regarding yb
- audi a3 warning lights problem
- 300bhp focus rs ??
- Rs turbo wireing loom help please!
- In etched green tint glass
- Quick Vehicle Search
- Car fabrication company's in the north west
- xr2 wanted
- T I M Gauges
- XR3i Wiring - Help pls..
- engine hoist Bradford area?
- recaro seat badges
- Stolen Saff. Heartless scumbags...
- ATM sport fraud again..
- Are Escort van doors the same as 3dr escort doors
- Cooling question
- Odd problem since service
- Scan gauge focus rs mk1
- Bloody DMFs!!
- Where to get exhaust gaskets for a rs turbo
- Changed the Focus RS to this
- how much shall i pay??
- Ka leaking thermostat housing.
- Please help!
- Newiems
- Koni Sport's, who refurbishes?
- Anyone have a diagram of internals of an rs turbo gearbox??
- BNIB crank on Ebay
- Good welder in berkshire
- Sytec fuel pumps v Bosch 044
- mk4 escort 1.4L
- Mk4 mondeo starting oddness
- 044 pump
- help injector question
- 1800 cvh in frst promblem
- Zetec turbo track car - cooling?
- useful link for all of you
- Compression test results
- estate recommendations please
- Transit oil leak
- Cheap saph ebay
- Now this would make a fantastic resto project!
- Roll Cage.
- Removing diff/rear beam on saff...
- Transit capacity info
- Bargain vehicles on eBay
- *STOLEN* Red clamshell car trailer
- L-Rover Disco 3's..Any good?
- Zetec turbo track car - gauges
- identify map sensor
- exhaust advice
- What sort of price,
- Z32 300zx tt
- remap questions
- Anyone know anything about mini one's?
- Newbie Fiesta ST
- Mk3.5 fiesta 40ml drop on 15s ??
- Audi S3 225?
- Whats best turbo damper ?
- seals where from
- yb pully refurb
- Escort rs turbo s1 bonus ball,anybody interested,£70 a ticket
- oil back to sump pipe
- Rev counter mod for W/S pic please ?
- underside resto who .?????
- Engine weight?
- Bwm 760i e38
- easiest way to put engine and gearbox back
- Turbo Repair Kits (where from?)
- Supermarket fuel experiment
- thread sizes
- ecu repairs
- Landwind X7?
- How much should i expect to pay for a mk1 focus rs?
- Dyno Dynamics 450d roller tach
- cheap exhaust wrap
- ford fair track time
- Saph cos fuel pipe nightmare :-(
- Wheel refurb in Herts
- T34, where to get one?
- ST150 duratec into mk3 escort
- Dash Cams "talk to me"
- tyre compressor
- K799 GAR
- Jaguar X types?
- Cam pulley ID help
- sunroof from glass to metal/plastic
- Aluminuim thickness for header tanks and fuel tank?
- 3dr rocker gasket replace best way?
- fiesta
- first running problem
- Something Different and Fixed by MSD
- Peco back box??
- Which lowering springs??
- ST220 please help
- Who wants to go fast - VMAX200 2015
- Trackday tyres?
- Transit van wont start (mk6)
- Some advice needed please on Sierra cosworth fuel gauge
- Help converting map sensor reading from MAP mbar to psi for boost pressure display
- vehicle signwritting
- Matt Lewis
- Charge cooler plumbing
- Escort Rs Turbo color change
- how to fit polycarbonate windows
- budget way to make a mk6 escort handle better???
- Sierra or Escort Cosworth chassis dimensions
- Best place for speedline course group a wheels
- Brake upgrade question.
- DVLA can't find my car...
- would a 3 dr t3 with a500 cooler= lag
- intercooler help needed
- 2wd cossie front hubs measurement
- Carbon fibre skinning?
- Turbo oil feed thread size etc
- Turbo feed , focus rs t25 turbo
- fiesta rs turbo wiring loom help please
- Topping up oil - 2006 Focus - 1.6 petrol - 85,000
- F1 testing
- Mk1 FRS engine start sticker?
- Exhaust Valves
- Sump plug oil temp sender mounts.
- advice
- Mk1 FRS clutch slave cylinder fitting
- Rs 500
- Cherry Bomb Exhaust
- Do you get full wide open throttle?
- 4x4 cosworth brakes on 400bhp zt rs 1600i
- Sapphire Cosworth rear lights wireing diagram??
- Ford Focus 06 Plate - Fitting Aux Problems
- Nissan GTR specialist- Workshop build thread?
- Anyone know??
- anyone know any info on this escos ?
- Shocking service from Brands Hatch performance
- broken locking wheel nut D:
- 3dr cossie headlining material
- passionbmw peeps!
- Mk2 escort
- Mk3 fiesta rs turbo
- Anyone local to me do tig welding
- Central day booking open
- handbrake lever question
- revo decals
- 4x4 people
- zetec or st170 engine
- Zetec turbo build- what else do i need?
- Mk1 Dashboard. Wiring help required please.
- anyone fancy retrieving these abandoned cars
- Best flexable gasket sealer ?
- can you still get all the boot badges for a 2wd saff
- Bloody Halfords!
- Mondeo 1.8 MK3 2005 Problems
- escort zetec on bike carbs??
- Jenvey throttle bodies on a puma 1.7
- Mk3 fiesta 1.3 conversion to a 1.6 zetec s engine ? Need info!
- Checking if a Car is Cat D?
- Big thanks to Jamie at Jamsport
- Automotive electrical connectors - where to get them?
- who is the best to set up my sierra 4x4 cosworth in scotland
- Goodridge or torques fittings?
- Picking up a car with no MOT?
- sump gasket
- 'Cosworth' front driveshafts
- Focus brake master servo thread and pitch
- Fuel cell set up
- Mercedes Vito CDI 111 Propshaft
- Cosworth YB crank...
- 90 spec type unpainted base bumper
- Are these focus RS?
- New DMF + Clutch 'bedding in'
- Cheap petrol = big engines
- On the pricey side?
- wet belt on a transit connect
- engine oil for 1.3 hcs?
- Ford 2.8i turbo technics advice.
- Valve stem oil seal help
- Anyone used A.L. Developments.
- How to find out Map in your car and who mapped it
- Clearance
- Goodridge hose fittings
- Torques filter and 044 mount
- DIY Zonda
- Mondeo - flashing glowplug light??
- Anyone know where my old cossy is?
- My new cosworth
- terraclean
- whats the going rate for fiesta rs turbo headlight covers?
- engine power
- Zetec cc increase
- ford 2.8 v6 metering unit info needed.
- Ford 6000cd expansion?
- Power levels and injector flowrates
- Bike carb cvh Ford Orion help
- RS Turbo EFI Running Issues and Turbo/Block Issues
- cheapest way of running zetec on carbs
- ive got a vibration
- TCA
- Lambo crash 200mph
- Zetec turbo - oil drain
- Toyota Yaris 1.0, banger woes
- Supra diff conversion...
- anyone with a engine leak tester local to bromley in kent want to earn some ££?
- high km Mondeo's
- 2wd / 4x4 rear diffs ?
- clay bar or clay mitt
- Top Gear on Red Button now
- Connect engine swap
- Good 2wd head gasket
- what grade of Alloy for brake brackets
- Clutch choice for 300bhp zetec turbo
- Cat or dpf?
- I like this a lot
- What head gasket to use on my zetec turbo??
- One for the derv boffs
- h&r or eibach
- MOT Testers
- Focus 1.8 idle rev problem and continuously stalling
- rs cars nowadays
- How much power can a T5 gearbox handle
- Baileys dump valve - which one?
- Help Identifying Map Sensor
- #PassionFord 2015 Shows
- heater and fan knobs mk3 focus
- 2.8 cologne engine adapter to vw gearbox
- Aux belt/fan belt squeaking and other noises?
- Justr fitted some Ahmed springs to Bilsteins problem...
- Help with ST170 alternator
- Underseal/stonechip
- Turbo exhaust manifold...
- engine change
- using car foam
- 2.5 Transit injector question
- Sapphire Gaz Gold Spring rates
- best place to get custom drive shafts made
