Sytec fuel pumps v Bosch 044
I'm looking for any information about the differences between the 2 pumps.
Has anyone used or using a sytec one? Are they ok as there is a big price difference between the two.
Any help appreciated as always!
I think this is the one Mark Shead rates (system)
A 044 is fine, a DW350IL is the same fitment but flows about 20% more than a 044 but that's prob a bit much for what you are wanting,
I have not tried a Syntec 044 style fitment to be able to comment on that, I use there 450 version for fitment in the Evo or Escort cosworth.
Mark
Mark
Mark
Mark
Current draw ?
At 40psi most flow tests for an 044 seem to be in the 300-330 lph range, not that anyone ever runs a boosted setup as low as 40psi in real load conditions.
edit, found this. They state the pumps are competition use only...are they reliable enough to use on the road ?
http://www.deatschwerks.com/resource...el-pump-tech-2
AMS 044 vs older Walbro ( not sure what their modified Walbro is...it seems to massively outflow a normal version )
JK12
33
26-04-2021 12:09 PM
