Good 2wd head gasket
Going for some head work and will need a good head gasket and bolts after as it'd only a 205 block can any one recommend please.
Cheers si
Cheers si
ybo 611 (group A) or a standard small turbo escort cosworths one will be fine with standard genuine ford bolts
get them and all your cosworths parts from matt lewis motorsport
http://mattlewismotorsportonline.com/
steve
steve
These are the same thing, ring matt he has them
http://mattlewismotorsportonline.com...inz-1396-p.asp
as for the wrc gasket yes if the head and block have been skimmed prior to fitting it if not then no, use what I've suggested above
steve
Billy_RS (19-01-2015)
I agree with you, I had a new 200 block, wire rung with a group A specification cylinder head with a group A head gasket fitted 15 years ago, run T38 with 2 bar boost and have never had a head gasket failure.
Billy_RS (20-01-2015)
