RS Turbo EFI Running Issues and Turbo/Block Issues
Got the lend of the correct map sensor and cured most of my issues. I now have another issue, it idles fine, then from idle it will misifre, sometimes a bit sometimes hardly anything until it gets past a certain point then clears.
Any ideas on this? Ive tried a Co2 Pot, checked the plugs and they are still sooted up from the incorrect map sensor, what kind of gap should they have? Ive checked for boost leaks and all seems ok!
Forgot to add, when I start it pretty much runs spot on straight away might I add, takes 20 secs then I get issues, even if its been running for ages ill knock it off, start it back up and it will be fine for 20secs
Another fault I have is the turbo manifold is touching the block breather blanking plate causing my manifold to blow badly. Ive countersunk the bolts to the breather but still issues. Any ideas on this to?
Thanks guys!
Thanks guys!
marky_g
15-08-2015 10:43 AM
