Advice regarding yb
Advice regarding yb
Hi guys. Trying to decide if it would be better for me to break my new built yb engine or sell complete. Want to get as much back as I can really.
Any advice most appreciated. Cheers.
New 0.5 oversize mahle pistons
16 new tappets
Hd thrust washer set
Niel roper head porting good for 500+
Arp head stud kit
Arp Conrod set
Arp flywheel set
New small end bushes
0.25 big end bearings acl race.
0.25 main bearing set
Group a head gasket
New bottom end set
16 exhaust to head studs
16 exhaust nuts
Aux shaft bearing
Timing belt tensioner
Group a Cambelt
New water pump
Motorsport leads
Bd 14 & bd 8 cams
Vernier pulleys
Siemens 83lb injectors
Brand new t38 turbo
4x4 inlet with 12mm spacer.
All original engine bits painted and freshened up.
Think that's about it. All brand new items from Matt Lewis. Not even run yet.
16 new tappets
Arp head stud kit
Arp Conrod set
Arp flywheel set
Group a head gasket
New bottom end set
16 exhaust nuts
Aux shaft bearing
Group a Cambelt
New water pump
Motorsport leads
Bd 14 & bd 8 cams
Vernier pulleys
Brand new t38 turbo
zetec turbo
16 new tappets
Arp head stud kit
Arp Conrod set
Arp flywheel set
Group a head gasket
New bottom end set
16 exhaust nuts
Aux shaft bearing
Group a Cambelt
New water pump
Motorsport leads
Bd 14 & bd 8 cams
Vernier pulleys
Brand new t38 turbo
16 new tappets
Arp head stud kit
Arp Conrod set
Arp flywheel set
Group a head gasket
New bottom end set
16 exhaust nuts
Aux shaft bearing
Group a Cambelt
New water pump
Motorsport leads
Bd 14 & bd 8 cams
Vernier pulleys
Brand new t38 turbo
I was aiming in the region of a comfortable 450 but may do more. The engine alone owes me 5k ish without the original engine i started with so that's what I would want or i would break it.
Sorry guys it has standard head bolts not ARP ones. I was reading spec from original quote from Matt lewis but then was advised the arp kit was toilet.
The block is a 205.
The block is a 205.
mk3ste
17-10-2021 10:09 AM
Mc5506
05-10-2015 09:57 PM
rsguy
44
29-09-2015 03:29 PM
