Sponsored by:
Sponsored by:
Jenvey throttle bodies on a puma 1.7
Old 26-01-2015, 06:37 PM
turboroots
turboroots's Avatar
Default Jenvey throttle bodies on a puma 1.7
Hello all
I'm looking at getting a set of jenveys for my fiesta 1.7 mk5 zetec s
It's going to have uprated cams full Milltek system bigger injectors
And upgraded fuel pump and omex 600
What do you think
Are the power gains good
Thanks
Old 26-01-2015, 07:15 PM
bagginsRSturbo
bagginsRSturbo's Avatar
Originally Posted by turboroots
Hello all
What do you think
Thanks
Sounds like a good plan,power wise 150-160bhp
Old 28-01-2015, 09:24 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
No idea on the power but arnt the injectors direct to head on the puma? Meaning that you could fit carbs for the air control and just not connect a fuel line up.
Old 28-01-2015, 11:46 PM
lacey
lacey's Avatar
Isn't that the same as having throttle body's with no injector mountings ??
Old 29-01-2015, 10:37 AM
It's Czech Mate
It's Czech Mate's Avatar
I'd expect to be knocking on 185 if the rod bolts are changes along with the valve springs and the rev limit raised
The head will flow 200bhp-ish as standard, just make sure the cams are the right ones and the exhaust manifold is up to the job
Old 29-01-2015, 12:16 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
Well yes, but carbs can bought cheaper.
i have no idea what the standard injector will flow either.
i was looking into this with my old puma as i have some yamaha thundercat 600cc carbs in the shed lol
Old 29-01-2015, 07:46 PM
Churtz
Churtz's Avatar
I dint think these make massive bhp numbers....but impressive torque. There was a girl that done it on her mk4 fiesta on here a few years back with jenvey direct to head itbs
Matt
Old 29-01-2015, 08:01 PM
CrOwSoN15
Ben
CrOwSoN15's Avatar
Listen to this man.
You can just about make 160 at a push on the standard inlet with something like SS4 cams or Lightning Motorsports equivalents.
Old 29-01-2015, 10:07 PM
J1mbo
B1mbo
J1mbo's Avatar
11:1 cr
Mild ported/flowed head
Racing puma cams with optimised exhaust cam timing and mapped Vvt inlet
Stainless tubular exhaust manifold
42mm tapered Gsxr throttle bodies
Rod bolts
This gave 182 bhp at 7000rpm
It would not give a single bhp more!
The headwork is important. The head is good but needs work!
Racing puma spec cams are good but slightly bigger will help if looking for more power than this as they're about at the limit.
Skimming the head 27thou will take it from 10.2cr iirc to 11.0:1 cr
May help you. This is a genuine 180bhp engine you will struggle for more without going more ports built bottom end, cams and springs.
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
mk3ste
17-10-2021 10:09 AM
Brickhouse
14
03-10-2015 07:28 PM
youngben
27-09-2015 09:37 PM
Marv888
26-09-2015 03:44 PM
Quick Reply: Jenvey throttle bodies on a puma 1.7
