2002 Focus starting / running problem
Old Jan 31, 2018 | 10:06 PM
M7 COS's Avatar
M7 COS
Default 2002 Focus starting / running problem
My dad has a 2002 Focus 1.6 Ghia. It developed a running problem and now has a starting problem as well. My brother in law is a Mercedes technician and this is what he's tried so far:
Vehicle cranks but doesn’t fire.
- Removed fuel pump and checked. Pump activating.
- Checked spark at each cylinder and ok.
- Completed compression test and passed
. Checked HT leads and no issues
Cleaned throttle butterfly but still the same issue.
Managed to get the vehicle started once and as more throttle is applied vehicle cuts out.
Anyone had similar problems or have any ideas how to fix it?
Thanks in advance.
CheeRS
Old Feb 1, 2018 | 01:59 AM
t230's Avatar
t230
mass air flow sensor? crank sensor? even an air leak can cause this (if it didnt start at all id say definite crank sensor)
Old Feb 1, 2018 | 07:36 AM
gcfcos's Avatar
gcfcos
It needs plugging into a decent scanner before doing/changing anything matey to see any fault codes and also live readings. One thing u can Check is that when u crank the engine does the Rev counter move up very slightly? If so then u can tell it is getting a crank signal and can rule out the crank sensor then
smngry
May 29, 2013 07:55 AM
frany8472
Ford Focus (All Models)
Nov 11, 2012 07:31 AM
jk8388
Apr 27, 2011 01:03 PM
B16JUS
Jun 8, 2010 06:57 PM
kimzie
Ford Focus RS
May 5, 2010 12:32 PM
