Cosworth breakers
does anyone know any good breakers I'm in the process of rebuilding an escort cosworth but have loads of bits I need to buy however it's proving somewhat difficult to find the bits.
Thanks in advance
Mt motorsport used to break a few plus I bought stuff from RS Cosworth breakers near Fareham.
Why not list what you need and we can see if we can point you in the right direction?
Cheers for the replies, the bits I'm trying to find at the moment are full boot carpet, fuel sender locking ring and big turbo fuel filler neck with the pipe work and petrol cap. There's loads more bits but this will help out to start with.
Thanks.
the fuel sender locking ring is the same on all injected 1990 sierras onwards with the pump in the tank, you should find one of them breaking somewhere
also a guy on escortrscosworth.com used to make them.
here you go
https://www.escortrscosworth.com/for...r-ring-spanner
steve
here you go
steve
How you doing mate? To be honest it sat about for a while, only really starting to get stuck in to it last year, had both rear chassis legs done, inner seals battery tray and petrol cap, all sorted. Stripped all the under seal epoxy primed it undersealed and painted the underneath and engine bay, hopefully the body work will be finished this month.
It's come close a few times to being sold, but i know if it goes I'd never replace it, hoping to have it done for classic ford this year but struggling on getting parts, 😢
Gaaables
11
18-10-2004 08:22 PM
ImaRacing 700
27
11-10-2004 12:19 PM
