EFR 7064 with standard head bolts.
Looking at upgrades to my engine but don't want to pull it apart just to have long studs fitted as engine is only about 3k miles old.
My engine is a 200 block with .5 pocketed pistons. Mild port and polished head with BD15 inlet std exhaust cams. Hart plenum and top feed cooler. T34//63 turbo. New aftermarket management with 1050cc injectors.
Question is can I fit a EFR 7064 twin scroll plus manifold without issues of head lifting and causing problems as it's on standard head bolts ? Not looking to break any power records but would like a bit more power and torque until such time as money allows for a all singing & dancing bullet prove engine build
**RS COSWORTH**
can't see it being a problem just have it mapped on low boost.
**RS COSWORTH**
I have low boost set at 1.5 bar that should be around 420ish. I'm sure Mark Shead said it could be set low than that when we out mapping.
Mine was 400 bhp at around 1.5 to 1.8 iirc but I also ran 469 at 2.2 bar. It does have a metal head gasket though and when we took the rocker off the other day it looks to have arp studs but I don't think they do a lot over standard. Even on low boost the efr was a VAST improvement over my t34...less lag and 100 bhp more plus loads more torque low down.
So an EFR 7064 is all good on standard head bolts as long as you don't go mad with the boost as a big improvement over the current T34 I have ?
Next question is what's the best one to go for internal or external gated ?
I had to go internal for packaging reasons but don't know what is best. The 7064 is like getting in to a car 20 years newer. Just make sure you have the right manifold and get someone like Mark Shead to check your exhaust is up to it as I think that can be a restriction around 400bhp.
Can I ask why you have such big injectors? With the right bits/turbo etc they could give up to 500bhp. Are they Low impedence or high impedence with new management?
I have had a new 200 block for a long time, no long studs , wire rung and group A head gasket, group A ported and polished head,T38 with billet comp wheel running 2.0bar boost,890cc Siemens injectors etc etc and approx 450bhp . So far had no problems with head gasket failure.
Apart from long studs all the bits on my engine are spect to allow me to run 500 bhp.
Mark fitted 1000cc injectors to mine too to future proof it. I also went coil on plug but that was to modernise it.
My engine will end up getting a rebuild at some point but I just didn't want the expense of it just so I can have it long studded to run a bigger turbo.
Looks like a manifold and efr 7064 is the way to go but now need to find out if it would be better to go internal or external wastegate as don't want the expense of a second manifold later on just to change it.
Pros and con of internal and external on these turbos ?
Internal works well on mine but Mark prefers the external I believe but cannot remember why, he can sell you the turbo, manifold and explain why you need the spec you need etc. give Mark Shead a call 07768 356204
Location: it's not where you are, it's where you've been and where you hope to be
a second vote for coil on plug (+ denso iridium plugs) - a significant upgrade and cheaper than a new set of plug leads!
as you're fitting after market management you can bin the ancient cosworth plug leads, amplifiers etc and directly drive Toyota COP's.
Agreed, AND you can even go over to cam trigger and delete the ancient distributor from the engine bay (I know there is nothing wrong from taking the trigger from the hall on the dizzy but to me it just looks soooo old fashioned)
I was already on a coil pack as I have removed my pectel T2 but new management has coil on plug and runs the Honda h20 coils.
Cheers Paul
So which is better with these EFR turbos, internal or external gate and why. I know which I would go for on a normal turbo but not to clued up on spec and what works best for the EFR range.
Also I see quit a few Evo,s running external gate but with 2 wastegates but only seem to see 1 on the cossie manifolds.
Is there a reason for this ?
Mark Shead is your man to ask for what’s best for your application, he is the efr guru
Cheers Paul
Cheers Paul
AJC
693
15-12-2018 03:07 AM
Will Pedley Racing
Ford Focus RS Parts for Sale.
25-07-2016 06:52 PM
Damo V
15-06-2005 09:11 PM
