Question for the CAD CAM people on here - MK - MT - people experienced in toolpaths
I've got this to make out of aluminium.
Jag diff cover with Sierra diff mount.
Is there any software out there that would recognise the shape of what I'm trying to produce from the solid model without laboriously picking individual bits of the profile and assigning tool paths for each part ?
Until recently I had assumed you just told the software what tool you were using, how much material you wanted left on for finishing and it worked it all out for you from the solid model
Up to this point I've never used a CAM program and always used Heidenhain parametric programming to get where I need to be.
Thanks in advance for any input
mail it to me as a dxf file
mark
Mark V8 (06-06-2016)
Yes it does
But I have to ask, why would you want to machine in one attempt?
From a time perspective it makes sense to rough it out then finish with a smaller cutter
I would like to set my x y z at the top middle of the the job.
Tell the software what cutter I wanted to use and how much to leave on and then spit out a tool path !
I would like to rough and finish in the conventional way.
Just wanted to know what software was capable of recognising the whole profile.
Ideally I would rough with a 25 dia round tipped cutter and then use a ball nose for picking out all the detail.
MONSTER (07-06-2016)
Mark V8 (08-06-2016)
Would say FeatureCam be capable of recognising the complete profile and just do what it can with a 25mm dia round tipped cutter if I wanted to just rough it all out to within 0.5mm for example ?
I understand that other steps would be needed, and it would obviously leave all the gaps between the fins.
Gary @ RS CLASSICS
05-04-2016 07:12 AM
Gary @ RS CLASSICS
25-03-2016 08:33 AM
