Sierra Diffs
Old Apr 4, 2016 | 12:51 PM
loggie's Avatar
loggie
Default Sierra Diffs
Read the threads that came up on the search but wanted a fresh view.
Thinking of upgrading the diff in my 2000e. Obviously power limitations etc do not apply. Would like something that will act as a 2wd as and when required - not planning on giving the car death but if the notion to step out would tickle me i would like to know its going to lock every single time (welding is not an option).
Currently have a cosworth LSD but it can be hit or miss if it locks.
Tans-X and Gripper plated are the two I am thinking between - Would they come up for sale second hand often?
Of these which would be the better option? Car is not used as a daily driver.
Any advice welcome, cheers
Old Apr 6, 2016 | 04:57 PM
R4N SS's Avatar
R4N SS
If your LSD diff is not locking up properly it needs a rebuild mate
Old Apr 6, 2016 | 07:45 PM
DAN400's Avatar
DAN400
theres a quaife for sale in antrim for 600 I think it is , I sold my gripper a few weeks ago for 800
that's a very cheap quaife imo
Old Apr 7, 2016 | 09:11 AM
stevieturbo's Avatar
stevieturbo
C**t
You'll be lucky to find either second hand, and for diffing etc the Quaife would not be the best option. Gripper is probably best bet.
There are people who claim they tighten the original VC LSD....although what that seems to translate as is they take it apart, dump the VC fluid and ram in some metal plates to force the diff to lock....until it eats up the metal plates probably destroying the diff in the process. Not sure how long that takes.
The correct way would be new VC plates and fluid...but that is very expensive.
Old Sep 1, 2016 | 08:16 PM
kosi's Avatar
kosi
Default sierra diff turns then seems to jam ?
Hi
I recently took my diff out and replaced radial drive shaft seals
to do this i sat it on its side and knocked the seal in - both sides
now when i try and turn it by hand it turns then seems to jam ?? turn it back and rotates but then also jams later ?
could i have knocked something loose ?
thanks
zetaboostboy522bhp
Feb 12, 2017 10:00 AM
xr3-2-rsturbo
Mar 13, 2016 08:22 PM
155lee
Feb 25, 2016 09:02 PM
cutch
11
Feb 22, 2016 07:43 PM
fordsteve77
Escort MK 5 / MK 6
Feb 13, 2016 08:47 AM
