Anyone own a seat Leon fr170 59ish reg
As above I'm thinking about getting one for the wife, any one had any experiences with them ,it's a 59 reg 170 bhp with the k1 pack
,are they reliable , built well , anything I need to look out for
Thanks
Thanks
If petrol TFSi or TSi engine?
If diesel PD or CR engine?
I have a Leon, on a 59 plate - a 1.4 TSi Sport.
The Leon is a well built car. It's basically a VW Golf/Audi A3 in a sharper suit and has a lot of kit as standard, the only critisicm so far is the wheel alignment/tracking is put out easilly, which leads to premature tyre wear. So have it checked on the Hunter 4 wheel alignment kit
Also check that the scuttle panel isn't leaking (the black plastic trim at top of bonnet which houses the windsreeen washers)
Lift the bonnet up and check the soundproofing for mould, if its mouldy, then its leaking (this was fixed by a recall so should have been fixed under warranty)
if its not been fixed, then this can lead to water dripping onto the coil packs - not good.
Other than that it's a well sorted car, better looking than the Golf or A3 IMHO
Take it for a drive you'll be pleasantly surprised!
if you check out seatcupra.net theres loads of advice on there:
http://www.seatcupra.net/forums/
it'll be the CR diesel engine then, rather than the PD, which is a bit more refined. The issue with the scuttle panel and wheel alignment will still apply so double check those
hop on over to seatcupra.net and see here:http://www.seatcupra.net/forums/forumdisplay.php?f=242
I bought my wife one brand new 2 years ago, excellent car does about 55,56 mpg on a run. about 45,46mpg pottering around town. Havent had the car remapped yet as its still under warranty. These cars were a bargain 2/3 years ago as Seat had them at VAT free meaning you could pick a brand new one up for Ł16300 !!! With getting mine VAt free its market value is still about 15k meaning its devaluation as only been about Ł700 a year!
The equivalent golf GTD was nearly 10k more
![](http://imageshack.us/a/img6/9734/imag0361ji.jpg)
![](http://img.photobucket.com/albums/v688/v16ean/Seat%20Leon%20Fr/DSCN9880.jpg)
Diesel particle filter, clog up if cars are just used around towns etc. need to give the car a good blast out every now and again. Mines been ok on the new cr (common rail) engine. is the problem more prone on the old pd engine? i dont know.
07-10-2015 12:56 PM
