Are saph windscreen seals still available ?
not quite sure what you mean by inner? are you talking about the trim that goes round the windscreen which you can see from the outside?
if you are, pattern trims are still available, a quick enquiry would suggest they are not available from Ford any longer
£31.59 + VAT from Autoglass supplied only, available next day and the code you need is a 3543asmh i think, if you give me your reg i can check
ahh yeah, i know what your talking about. Its like a daming trim that slides onto the aperture so you can see the metal from the inside?
that isnt available anymore and i very much doubt if Ford will have it, unless yours is damaged? you can still re-use it.
best off speaking to a breaker or find a sierra in a scrppy
The trim for the windscreen is indeed a 3543ASMH
Moderator
![](https://passionford.com/forum/images/pf_trader.gif)
![](https://passionford.com/forum/images/pf_staff.gif)
yes they are pretty universal used to cut these up and fit on all manner of cars when I was stuck for a trim, transit old outer trims I used to get through by the bucket load as any screen fitter knows all too well
07-10-2015 12:56 PM
