will a T34.55 do 400bhp.........
Old 20-01-2013, 09:14 AM
H15 FSC
H15 FSC's Avatar
Default will a T34.55 do 400bhp.........
im looking at changing my setup, and was thinking of a t34.55 from TT.
will these flow enough for a genuine 400bhp??,
probably run greys or siemiens 83lbs.
Old 20-01-2013, 09:39 AM
Steve the Plumber
The original Rouge Trader
Steve the Plumber's Avatar
In a word, no!
Old 20-01-2013, 09:45 AM
H15 FSC
H15 FSC's Avatar
thought there was a few guys running 380bhp on a .48
Old 20-01-2013, 10:05 AM
RSGARETHW
always working
RSGARETHW's Avatar
T34.55 is a comfortable 360-370 bhp turbo all day long from what I have been told after talking to various tuners about them
Old 20-01-2013, 10:09 AM
jamie956
jamie956's Avatar
Mine made 389.3 on a .48 with 55 blacks,
Old 20-01-2013, 10:10 AM
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Just pretend it makes 400 on a .55 your mates wont know & i doubt you will get it on a Dyno
Old 20-01-2013, 10:32 AM
Rsmat
300+
Rsmat's Avatar
Mine made 407bhp and 412ftlb on two separate dyno's with proof and witnesses ... But I am wringing the life out of a Maram shafted turbo.. Here's a 400bhp run which was the third attempt.... Car very very hot.
Look at all the other cars making what they should really..!
Old 20-01-2013, 10:44 AM
H15 FSC
H15 FSC's Avatar
i asked a question about IF!! 400 could be possible on a .55, as SCS did a couple of .48 @ 380bhp. and why would i make up figures when there easy to achieve. and why would i not put it on a dyno??
Old 20-01-2013, 12:23 PM
Staffi
Staffi's Avatar
I've personally never seen one make 400 and I've been to lots of Dyno days with Cossies on T34 setups with various Specs etc.
Personally I wouldn't worry about what number it makes, I'd be looking at how nice it will behave and drive on the road, run it at a sensible boost and enjoy it, they're great at 360-380bhp with similar torque tbh, really enjoyed mine at this power.
Old 20-01-2013, 12:56 PM
Karl 3dr
Karl 3dr's Avatar
This is very very good advice!!
What matters the most is that it drives nicely on the road, whatever the power, tbh, I enjoyed my Sapph the most when it was around 380 on a T38, if it were me I would look at a .63 housing and then you're not gonna be ringing it's neck so much.
Old 20-01-2013, 01:00 PM
Mr RS500
Mr RS500's Avatar
How many 400 bhp cossies on greens and a t34 do we see on ebay ,, lol
Old 20-01-2013, 01:07 PM
turnover
turnover's Avatar
You probably would make 400 but you will have to run 2.3 bar boost or just max the 3 bar map sensor but the turbo won't last long if driven hard,just put a larger turbo on and run lest boost ,less strain on your engine ,or have a solid 350 ,360 hp with what you have will still be fun
Old 20-01-2013, 01:41 PM
Rsmat
300+
Rsmat's Avatar
Mine runs 36psi on 55's.
Old 20-01-2013, 02:36 PM
J1mbo
B1mbo
J1mbo's Avatar
There is no point in talking about peak boost pressure figures it is irrelevant. You need to know the boost at peak power, generally 6-6500rpm
400bhp is most deffinately possible but it is absolutely wringing a t34s neck.
Back in the day a lairy inlet cam, ported head and blues would do over 400bhp but turbos last from a few weeks to a few months. Hence after fitting in the car customers would have the boost a touch lower and run 380ish in the car.
Mike rainbirds .48 did 38*bhp (can't remember exact) on greens.... And did 172 mph at brunters, no dodgy figures with proof!
So there's your answer H15 FSC and with the right engine spec boost would be 2bar held and turbo speed insane
Old 20-01-2013, 02:56 PM
Staffi
Staffi's Avatar
Always the best way to prove power Jimbo
Old 20-01-2013, 03:06 PM
bigchez
bigchez's Avatar
Although I'm sure mike had a great engine, was that not also to do with the fact that fuel was more calorific with benziene and all sort of other chemicals in it too...........
Old 20-01-2013, 03:10 PM
Staffi
Staffi's Avatar
True matey, but to get 172mph it must have been a 380bhp or there abouts I'm guessing
Old 20-01-2013, 03:14 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
I think my 4i was at it's most usable when it was on a T34.55, light blues and a mild head port.
It made 372bhp peaking at 1.8bar on a set of DD rollers.
I might go down this route with the 3dr as im sure i will get very bored with standard power lol
Steve
Old 20-01-2013, 03:15 PM
1374lee
1374lee's Avatar
100% agree with Pete,run a little less boost and good reliable 370-380 or strap a larger turbo on and run less boost.Figures are irrelevant,you won't notice 20 bhp or so when it's on the road anyway.As Pete says go for how it drives and you want the turbo to last for a while aswell I'm guessing,good luck with it.
CheeRS.Lee.
Old 20-01-2013, 03:17 PM
J1mbo
B1mbo
J1mbo's Avatar
Quite possibly chez but in the context of the thread there is no denying that a .48 can do 380bhp thats what I was getting at
Old 20-01-2013, 03:28 PM
H15 FSC
H15 FSC's Avatar
cheers, so would a t34.55 be better than a t34.48 for a solid 380 bhp. want low lag. or should just go .63 and be done with it.
Old 20-01-2013, 03:32 PM
J1mbo
B1mbo
J1mbo's Avatar
Road car I guess? I would go .48 with an inlet cam and a nice map and have a reliable 375bhp they go so well on the road and hardly any lag with the .48
Old 20-01-2013, 03:33 PM
H15 FSC
H15 FSC's Avatar
yeah road car. also is it best to get a 2wd ex manifold,
cheers mate,
Old 20-01-2013, 03:35 PM
KSA-Cossie
KSA-Cossie's Avatar
I'd second that
Old 20-01-2013, 03:36 PM
J1mbo
B1mbo
J1mbo's Avatar
At that power level the 4x4 is fine and will help slightly more with response. Only above 440/450 you need 2wd
Old 20-01-2013, 03:39 PM
H15 FSC
H15 FSC's Avatar
cheers matey.
Lambchop
PF Idiot Sniper
Lambchop's Avatar
Originally Posted by KSA-Cossie
I'd second that
Shouldn't you and I have a wankathon over T38s instead? I dont regret changing up the way. Lag hardly comes in to it!
Old 20-01-2013, 03:41 PM
Lambchop
PF Idiot Sniper
Lambchop's Avatar
PS OP I have a set of greys you can have for nice price if you like
Old 20-01-2013, 03:44 PM
Staffi
Staffi's Avatar
And a gearbox etc too
Old 20-01-2013, 03:46 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
I'd second that
But mines better than both of yours
(banter like the OLD DAYS )
Steve
Sticky.
Sticky.'s Avatar
380bhp is a nice conversion and fast enough for the road.....don't go chasing figures.
Old 20-01-2013, 03:47 PM
H15 FSC
H15 FSC's Avatar
its converted to 2wd already
Old 20-01-2013, 03:49 PM
Staffi
Staffi's Avatar
Steve
Not in fucking pieces it ain't.
J1mbo
B1mbo
J1mbo's Avatar
Even better that conversion is ace 2wd!
Old 20-01-2013, 03:50 PM
Staffi
Staffi's Avatar
Good man.
Inlet will be fine as well pal.
Sticky.
Sticky.'s Avatar
Loving the Megane.
Old 20-01-2013, 03:58 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Nobody said anything about engines, just turbos's
Steve
Old 20-01-2013, 04:04 PM
Staffi
Staffi's Avatar
Steve
Mine's faster than all of you anyway
Awaits to be.
Old 20-01-2013, 04:06 PM
matthewpickup
matthewpickup's Avatar
i plan to run the t34 .63 turbo , greys, cams (bd14bd8) , valve cuts outs, 4x4 inlet/exhaust and a 380bhp msd off the shelf chip and well hope to see power of around 380bhp ish (needless to say lol) and i hope it will be safe as its a road car and it wont be driven hard all the time
Old 20-01-2013, 04:22 PM
Staffi
Staffi's Avatar
Don't forget good brake setup as well Matthew, very important, make a car quicker
Quick Reply: will a T34.55 do 400bhp.........
