escort rs turbo
hi, i am new to this site and need some help, the full story bought a very nice ford escort bonus 90, after a couple of months driving around with the 1.1 4 speed with slipping clutch thought it was time to turbo it
so i bought a full mfi wiring loom converted a old xr3i engine with turbo pistons arp conrod bolts, victor reinz head gasket with head bolts, new rings and big end shells and lots of chromey bits lol, everything is done and runs very nice only problem i have is when the engine is not under load it revs up really nice and can hear the turbo spooling up, but when i take it out on to the open road and give it a little bit it pops and bangs and feels like no turbo but i can hear it spooling then nothing just very loud explosions lol also the tick over is very high even with the idle screw turned all the way in if i weaken the mixture it doesnt want to start ive spent a very large amount of money and i am getting very dishearted with it, any help would be much appriciated, cheers, rob.
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
hi thanks for reply, turbo spins freely, its a rs turbo fuel pump, i know its got over boost i did have a collins actuator on it so removed it and put on the stanard one but still the same also have a manual boost controller and its turned all the way down, thanks for replying, cheers, rob.
do you have a boost gauge? i have found this in the past but only after been layed up for a few weeks/damp weather. i think it could be moisture on the hall sensor connector (dizzy). it could be that it needs a setup though.
hi, its got a new dizzy cap and rotor arm, new plugs and leads, thinking its the metering head as no matter what i do to the mixture it still ticks over fast can you repair them?
Hi ive played around with timing and mixture ive got the earth strap from gearbox to inner wing on and the earth from battery to gearbox would the one from intake lifting eye make it run fast? Cheers, rob.
Bit of an update fitted the earth strap behind the intake to inner wing no different then richend the mixture and advanced the timing and its running much happier but while ticking over its got a bit of black smoke, its got a 240bhp ecu manual boost controller and collins -31 actuator would it have to be really rich for the chipped ecu
Matt Baxter
16-09-2015 08:30 PM
muz
16-08-2015 12:57 PM
