General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Hi is -3 pipe ok to use as a oil feed pipe for a turbo. It goes from -6 out if the block up to a inline oil filter and i need a pipe to go from that to the turbo. It will only be 12" long.
If -3 is too small what would the best size to use?
The oil feed in my 3 Door is -4 I think -3 will be alittle small but I may be wrong as GT turbos have a restrictor down to 1mm so it's probably just good pressure you require.
What turbo have you got fitted?
Rich
