Foucs wont start ...
Drop 300 miles yesterday with no problem , got in this morning and it just turns over. The pump is not priming and there is no fuel to the rail ....
Dame thing need it for work Monday , ive checked fuses and relay all good ?????
Received 1,044 Likes
Check the electrical pin on top of your fuel sender/pump.
My mam n dad had a 51reg 1.6 16v focus that did this.Dropped the tank down and found the pin corroed and snapped off.
My dads 53 plate done this last week , drove off went for a walk ,no start
I checked it all out first Make sure fuel cut of switch drivers Kick panel has,nt been triggered
Hs pump had died as it was a 2 door exhaust and tank had to be dropped nightmare
4 door can be done from inside car !
What's your ecu light doing whilst turning it over?
Seen 4+ like this now where the coil goes and blows the coil side of the ecu
Some times its been a pig to start , no other lights on while cranking , 4 door no port hole in the floor will drop the tank 2m .....
There is a red light above the radio this is on while cranking , it flashes when the central locking has been set. Will check to see if there is any power to the pump when cranking later.
Were in the footwell is the switch n/s or o/s ?
DixieTheKid
11
06-06-2020 11:20 AM
TPM961
15-01-2018 10:50 AM
