Is there a big difference between a bolt in cage and welded
I can do ever roll cage one is a lot cheaper I no and will leave me with more cash for other parts,does it do anything to the handling have a welded cage?
obvioulsy the welded in cage will be stronger as it then becomes part of the structure of the car,the bolt in one may flex unless you also bolt it to the A and B pillars which will help.both will save you from a roll its depends on what you intend to do in the car and the level of protection you want
Resident Wrestling Legend
a bolt in cage will obviously be easier to fit/remove whereas a welded one is going to be in there for the duration
on the other hand, if you weld it in wrong, you can't just drill another hole in the floor
a lot of cages now i've seen have "gusset's" welded along the a piller's as this is where you will need the most protection
I'm not gonna sell the car at any point and I don't intend on rolling it lol, it had a bolt in cage before I bought the shell so it's ready for one to go straight in and would be a quicker way of getting on the road and like u said could just use a few gussets to strengthen it
borboyous
22-08-2015 11:17 AM
saph in dorset
14-08-2015 10:10 AM
track.focus'd
12-08-2015 05:53 PM
