Any brake experts? running out of ideas
The car is a Nissan Micra 2005 with ABS,
the wife's car has a huge amount of brake pedal travel and im at a loss as to why, the whole system has been bled, the discs and pads are fine (mot just passed) and I have changed the master cylinder, all to no avail. the rear hubs are fine and no fluid leakage
Could a new ABS unit be the cure? Im at a loss.
All help appreciated
Andy
Andy
Is the pedal travel there when stationary?
is the pedal travel there with the engine on and off?
Petrol or derv?
Did it just start doing it?
Are the brake pads free to move in the carrier?
Are the caliper slides free?
Are the rear brake shoes correctly adjusted?
Petrol or derv?
I bought it as a part ex fro a main dealer thinking it just needed bleeding, its petrol and the travel is worse when running, local garage have been over all the obvious
clamp all 4 flexi's, if the peddle is the same the problem is with either the master cylinder or the abs pump,
if it feels better then remove the flexi clamps 1 at a time, and when it goes the same way as before, your problem lies in that corner
Baby Cheesus
I had similar a few years back on a citroen dispatch.
It went to ats for discs and pads, upon collection i got to the end of the road and my foot hit the floor. Luckily they adjusted the handbrake and i just about stopped from rear ending someone!
Took it back to ask if anyone tested it before giving me the keys back to which one guy piped up so i threw him the keys and told him to have another go!
Basically they ended up changing the front callipers, rear cylinders, master cylinder all while trying to bleed it numerous times.
In the end my company had to trailer it to citroen and they bled it again but it was still shit. So all they would after that was fit genuine discs and pads. Low and behold the brakes worked after that!
So what im getting at is it could be the pads if they are pattern parts
jason_nike
18-08-2019 10:53 AM
Red_bull
09-08-2015 08:34 AM
