Rs Turbo engine identification, HELP!
02-01-2014, 06:26 PM
hey guys, need to know, how can you identify that the rs turbo engine is a factory turbo one, or just a normal cvh with turbo parts fitted??
02-01-2014, 08:21 PM
st170 breaking
The big hole drilled into the front where the oil returns from the turbo
Otherwise any cvh block looks the same really
04-01-2014, 09:16 AM
thankx mate, so how would they go around that problem?
04-01-2014, 11:32 AM
Quote:
Originally Posted by
Ryan_3
You can get the oil return put in to the block.
The cheapest way would be to put the return in to the sump
04-01-2014, 12:33 PM
04-01-2014, 05:29 PM
didnt get any pics to be honest!
04-01-2014, 09:12 PM
think car was an xr3i. problem is, I cant tell if it had a proper rst engine or they just bolted a turbo on its normal cvh
04-01-2014, 11:53 PM
st170 breaking
Rst conversion requires loom change
All rs injection system
There's a lot to change
You can just chuck it all onto a 3i lump but they don't last too long
05-01-2014, 07:48 AM
Only way mate is rip it apart. Then u can see.
Or stick a prope down the plug hole and have a look at the top of the piston.
Matt Baxter
16-09-2015 08:30 PM
IAN RS2k
18-08-2015 07:51 PM
