what engine is this
It's neither. It's a Mazda engine that came with some Ford Probes abroad. Can't find a picture of one with the Ford cam cover but found the Mazda version.
![](https://img241.imageshack.us/img241/4210/dsc01234smallre8.jpg)
![](http://www.miataturbo.net/attachments/miata-parts-sale-trade-5/23556-f-s-pa-fresh-rebuilt-fe3-dohc-turbo-stuff-manifolds-more-151-jpg%3Fdateline%3D1314397832)
EDIT:
A Ford one in another Mk1 Escort with a small turbo...
EDIT:
![](https://i227.photobucket.com/albums/dd200/jesiotrot/fe3/181098_3489088787587_557066088_n.jpg)
i guess that means its a good engine then, better than a ford, should be running the mazda pick up 5 speed then as well.
I guess they rotated that inlet manifold around ?? Also added a custom crank trigger wheel
they may have used bits off the mazda B2200 or is it B2000 pick up truck, they used the basic same engine and was RWD, finding out from the guy selling it but they not fast at replying
The i4 is a timing chain engine, and that's clearly a belt driven engine,
Manifolds are the wrong way round to be a zetec
So as above is the Mazda engine also fitted to late model 2.0 mavericks
The turbo on that mk1 looks quite naughty,
Never seen these engines tuned, if that turbo's normal for them ,then that could be fun
exhaust passenger side is correct for zetec (and duratec badged zetecs), I4, crossflow and it would appear the probe's mazda/ford engine, exhaust driver side for duratec, and pinto
i'll get my coat
