what the best way to paint my block
Pick-up P100 Power!
Any acrylic (Edit: epic fail aerosol / acrylic) rattle can paint is cool. The block believe it or not doesn't get that hot. Its always good measure to put a primer underneath.
Mate of mine rattle can'd his block in white to be fair it stayed white for quite a while.
White spirit is no good for any paint other than the stuff you do your skirting boards with!
Paint wise, I've used Halfords, yes Halfords own high temp engine enamel for years. Really good hardwearing stuff and you can get a good finish with a fine brush.
For an engine I do the final de-grease with aerosol brake cleaner as it is easist. Better still is panel wipe but it is tricky to use on an engine.
Still looked good when the block was scrapped yeah lol just a bit oily.
I used the white spirit to clean the dirt/dust off then left to dry and then painted. Seemed to work fine!
Grant
Grant
rsguy
44
29-09-2015 03:29 PM
