coil pack
Hello,
i have 55 plate Ford Fiesta 1.4 petrol, due to engine warning light flashing intermittently while driving, AA diagnose that it 's the 'coil pack' this coil pack has been changed. but the engine warning light flashing intermittently, also intermittently it feels as if the power has been lost, some time the car would judder while driving.
can any one help what the problem might be please
PassionFORD Member
Failing coil packs do not generally bring up the EML light. Also, a flashing EML light normally indicates a more serious fault. The codes should've been read and it should've been establish what kind of misfire the engine is reporting. Do you have any idea what the codes were? It isn't overheating is it?
No sorry i do not have the code, but it was mentioned that the cylinder four has misfire,
this morning i went out and after approximately 1 mile the engine light flashed 3 times then went off, it seemed as if i have lost some power while driving.
while am still investigation if i continue to drive will it do any further damage?
i am looking to change the spark plugs, fuel filter and the ignition leads may this will help???
PassionFORD Member
That's certainly a logical starting point but you may be throwing money at it unnecessarily. You can swap leads 4 and 3 and then swap spark plugs 4 and 3 to see if the misfire changes to cylinder 3. That should narrow it down. Did you replace the coil pack with a new item? I wouldn't drive it too much until you figure out what is causing it.
Thanks for your reply
thanks
the coil pack was replaced with brand new one
You are always better to change plugs, leads and coil pack at the same time, it as been known for a new coil pack to be damaged by not changing all 3 together.
07-10-2015 12:56 PM
