PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 [95] 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114
  1. Indicators
  2. alloy rad question for s2 folks
  3. PECTEL BOARD INTO L6,
  4. Converting an MFI to EFI, slight problem please help!!
  5. Standard RS Turbo Cam.....anyone know theyre stuff??
  6. RELAY
  7. Turbo Cooling -- Oil and water
  8. Simple Wiring question! (Help a n00b)
  9. zetec alternator problem:not charging
  10. Modified Sump
  11. Pedal box for escort cosworth
  12. how do u test a throttle position senser on an rst?
  13. FRST missfiring
  14. Leakage
  15. sierra xr 4x4 prob.
  16. xr3i nightmare
  17. Wiring an RS 1800
  18. Mondeo Zetec 2.0 1998 Unichip AND steering wheel fun !
  19. Firing Problems with my FRST
  20. Vacuum hoses and crankcase breathers
  21. CV Joint
  22. a bad "cold" start on 2wd
  23. Turning up fuelling
  24. ANY IDEA'S
  25. tappety S1 turbo after oil change?
  26. Fitting twin 40s?
  27. RS1800 Power Steering unit Expensive problem
  28. welding gas
  29. 4x4 saph cos noise
  30. polycarbonate windows
  31. fiesta ztec 1.25cc
  32. the problem will not go!!!
  33. blanks for foglights on saph cossie
  34. Cossie steering help
  35. boiling brake fluid & tramping axle
  36. FAO ELECTRICIANS/ ALARM GUYS 1.8 zetec tach wire
  37. car radio help
  38. welding help
  39. Which will cool best 1x 4x4 or 2 x2wd I/coolers?... Pics
  40. Conversion
  41. cossie plugs in rst what plug gap
  42. Engine racing and stalling !
  43. Lambda sensor unusual
  44. Rattles n shakes
  45. strut braces for s1
  46. 205 block
  47. 1.8 zetec runnin a bit lumpy
  48. Cossie problem...any advice?
  49. boot spoilers
  50. Quick question about MK6 Escort Cab!!
  51. CAPRI LSD QUESTION
  52. escort dash (rev counter) help
  53. frst fuel pipe to tank connector??
  54. rst k jet-tronic bigger injecters
  55. Fitting 2wd four pot calipers onto mk4 escort....
  56. xr2i chip
  57. sunroof
  58. Engine and gearbox question
  59. Too much power (well torque) for standard clutch?
  60. Gerbox gone?
  61. 2wd cossie hot start prob
  62. which RS style intercooler
  63. F*cked Cossie
  64. porsche brembos on a 3 door
  65. ST170 Exhaust Manifold
  66. ka 1.8 zetec !!!!!!!
  67. rev counter
  68. Rst engine should i do it?
  69. scary moment in escos!!
  70. cam belt too tight
  71. green 803 help
  72. help needed. Connecting Oil Pressure Sender.
  73. ZETEC TURBO SOUNDS LIKE SCOOBY ON IDLE
  74. xr2 cvh ques
  75. 2 cossie questions 4 ya
  76. ecu change from l6 to l8
  77. Escort RST oil guage!!??
  78. C02 adjustment on Cosworths
  79. poly v belt on 1.25 ztech fiesta 51 model
  80. cossie ecu upgrade
  81. lights on escort rs turbo
  82. Xr3i Spark Plugs
  83. Urgent help with mk6 escort rear shoes!!
  84. 2 stage boost
  85. Just a few quick question's
  86. key remote coding
  87. Smoking cossie - hard to believe!! NOT
  88. cam timing on zetec help help help
  89. FRST - revs dropping down too low when coming to a stop
  90. WILL A MK5 ESCORT POWER RACK FIT A MK4 ESCORT??????
  91. OIL BREATHER SEPERATOR
  92. plz help
  93. front hubs s2 escort.........
  94. bodyshop in essex
  95. breather and cossie engine (205 block)
  96. Focus 1.8 problem
  97. 2wd and 4wd fuel rails
  98. escort rs turbo no compresion piston two help
  99. rear wheel bearing!!!
  100. 2 litre zetec conversion for a mk 4 escort, what do i need??
  101. Will waving something metal in front of CPS have any effect?
  102. Not fit for this site (TD Mondeo probs!)
  103. escort cossie wheels on saffy
  104. rst into mk5 facelift
  105. Nitrous
  106. Will escort cossy interior fit.....
  107. what part of a loom do you need to run engine
  108. oil cooler rad
  109. BLOCKED MONGOOSE ?
  110. 4x4 cossie front wheel bearing change - DIY ?
  111. how do you remove airbag on mondeo
  112. zetec turbo conver5sion
  113. knocking and creaking
  114. Headgasket
  115. sorry guys!
  116. saph cooling fan wiring
  117. Series 2 RS turbo, blocks out when coming on boost??????
  118. Escos wheel nuts HELP!!!!!!!!!!!!!!!!!!!!!
  119. UNDOING GROUP A HEAD BOLTS
  120. l6 ecu problem
  121. MT75 gearbox whine
  122. Clean a Radiator and Intercooler.
  123. How low should a low comp engine be?
  124. RS2000 cam chain
  125. cabby rear disk conversion..........
  126. undersealing
  127. Cooling fans not working ( cosworth )!!!!!!
  128. external wastegate
  129. Just a stab in the dark but where......
  130. oil seperater
  131. small turbo escort cosworth
  132. 3dr boost problem
  133. ACT not working????
  134. someone help!!!!!!!!!!!!!!!!!!!!!
  135. tips to remove a 4x4 turbo !!
  136. cosworth over fueling probs?
  137. rs 2000 lifters
  138. running rough??????
  139. cosworth head bolts
  140. Aux belt set up
  141. Ditching the Cossie Distributor....Whats involved exactly???
  142. XR3i Valve strem seals - Oh s!@*
  143. Smoking Cosworth
  144. Gold members help needed!!!!
  145. Escort S1 RST - Turbo went POP
  146. any one got an rs box for sale
  147. Ignition management.
  148. cosworth engine looms
  149. Bosch Injectors
  150. help needed/s1 wiring
  151. quick help folks
  152. L8 and 4x4 TPS on 3 Door?
  153. wheel refurb
  154. plz help urgent guys
  155. how easy is it to fit a .........
  156. Cold Start Up Problem on S2 RST
  157. Coilpack position....Interference???
  158. Help? brake set ups on cozzy....
  159. COMPOMOTIVE ALLOY WHEELS HELP!!!
  160. COMPOMOTIVE ALLOY WHEELS HELP!!!
  161. crank pully on zetec wont come off HELP
  162. Garrett GT35
  163. escort si 1996 problems
  164. RST lump into a ford Ka
  165. rs gear box making noise
  166. xr2i 8 v problem
  167. Escort 1800 Zetec Flywheel
  168. series 2 rs turbo electric mirrors
  169. smoke smoke why does it smoke help any one plz
  170. offset s2
  171. rs 2000 turbo problem
  172. smoking on acceeration
  173. cossie smoking and missfiring, HELP PLEASE!!
  174. RS 500 inlet .... ???
  175. what injector for 5 th
  176. Petrol Tank
  177. Cosworth Throttle Body Cable Mechanism
  178. Series 2 cutting out - help needed!
  179. torque settings on a 1.9 yankie block
  180. Turbo question
  181. mk1 fiesta trouble
  182. zetec ignition?
  183. pinto ohc tuning
  184. T34 endplay - excessive...?
  185. 2.0 zvh esimated power
  186. my s2 sounds like a subaru
  187. tight cam in series 1
  188. help with 1.6s z-tec
  189. mf2 injector setup
  190. Timing
  191. fed up with crappy wiring loom!
  192. cvh head??? PLEASE HELP
  193. smoothing numberplate recess
  194. cossy an mk4 box
  195. 1.4 botom end xr3i head????????????
  196. Valve guides on a RS Turbo
  197. Running in, Help required
  198. Cut out front bumper?
  199. 205 block
  200. idle control valve
  201. what actuator is this???
  202. Knock Knock - Whos there? Weird bloody noise!
  203. COSSIE engine help/advice please!!!
  204. 2wd cossie box
  205. 4x4 cosworth funny noise after driving!!
  206. 380MM AND 6POTS WILL THEY FIT?????????????
  207. s1 gearbox
  208. Garret T3 pipes and hoses?????Help Please
  209. cossie plugs colouring bit weird???
  210. What injectors....
  211. 1.6 rst engine into a mk1 fez base model...fit on mounts???
  212. YB's on unleaded petrol
  213. SI 16V ADVICE NEEDED
  214. YB 2wd thermostat housings
  215. Vari-Boost control
  216. Zetec into RS Turbo shell
  217. rst carbon fibre bonnet
  218. heated windscreen?
  219. now what .... :(
  220. 2wd drive aftermarket exhaust on a 4x4
  221. 2i 16v low down miss
  222. 4x4 cossie fan relay and fuse
  223. show me your air intakes on your cossies
  224. 4x4 fuel relay
  225. esc cos doesnt start
  226. No Spark from dizzy, yet there is 12 volts
  227. Grease for coilover-threads?
  228. rev limit on cosworth
  229. disconecting the water feed to turbo (will it damage it)
  230. amal valve disconected
  231. what spark plugs to run
  232. T3 TURBO HELP ON ZT
  233. EXHAUST FOR ZT
  234. just about done
  235. gearbox and diff oil
  236. Cam Timing Zetec Turbo ???
  237. 2.0 DOHC Sierra common engine problems?
  238. cabby efi engine transplant
  239. Nos and Flamer kit????
  240. s1 cabriolet rear lights and s2 cabby lights ..........
  241. xr2i 16v wheel & suspension help
  242. focus st170 bluefin wid air filter PROBLEM....
  243. cossie engine issue
  244. zetec coil pack help!
  245. 2.1zvh conversion, parts list? help please
  246. cosworth oil pump
  247. Wheel help
  248. which tyres???
  249. Boosting Problem
  250. Saphire front bumper................
