1.8 zetec runnin a bit lumpy
Old Oct 21, 2005 | 07:20 PM
sedan man's Avatar
sedan man
Default 1.8 zetec runnin a bit lumpy
ive jus bought a escort si 1.8 and it sounds fine but it just seems to judder now and again.i was in 3rd nailed it and it juddered quite hard.but wen im at low rpm it seems a bit judery aswell..would a tune up sort this or is summat else..???
Old Oct 21, 2005 | 07:24 PM
SierraCosworth's Avatar
SierraCosworth
Try disconnecting the MAF sensor and see what its like then, if it runs better then change the sensor can pick one up cheap from the scrappie.
Could also be the ICV which is causing it, try cleaning it in petrol or use wd40 then see how it is. But try what i suggested above first.
Old Oct 21, 2005 | 07:29 PM
sedan man's Avatar
sedan man
im new to fords mate i know what a icv is but dont know where it is..and as for a maf sensor im lost...
Old Oct 26, 2005 | 10:14 PM
stiffler_83's Avatar
stiffler_83
iscv lives inder the throttle body on the inlet manifold (u cant see it from the top) b4 changin it deffo clean it as there 80 squid! id also jus check the tps is plugged in...its the lil black sensor on the throttle body's right. and check the maf is plugged in... its joined to the air box...
to change the iscv is a one hand job.. reach along the under of the inlet manifold and unclip wires then with a tiny ratchet and an 8mm bit undo the 2 retaining bolts. to refit reverse process. hth
Old Oct 27, 2005 | 09:15 PM
perdu55's Avatar
perdu55
what mileage is on your car and when did it last have a set of plugs ?
Old Nov 5, 2005 | 04:53 PM
16vzetec's Avatar
16vzetec
could be lots of things.
plugs??
leads??
coil pack??
air leak??
if it happening on hard throttle then it sounds electrical like a missfire
Old Nov 9, 2005 | 08:13 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
GET IT ON ON FAULT FINDER M8 THAT WILL POINT U IN RIGHT DIRECTION
Porplus12
Sep 10, 2015 07:20 PM
Dubs44
Aug 21, 2015 02:42 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
gingerturbo
Aug 11, 2015 09:44 PM
