how do you remove airbag on mondeo
Old Oct 12, 2005 | 07:40 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
Default how do you remove airbag on mondeo
as above need to know how to remove air bag so we dont end up like de faced!!!!!
Old Oct 12, 2005 | 08:38 PM
runty176's Avatar
runty176
disconnect the battery for 10 mins to power down the e.c.u.
undo the 2 torx or 7mm bolts at the back of the steering wheel that hold the airbag on .
carefully lift the airbag off the steering wheel . unclip the yellow plug from the back of the airbag . the plug may need a bit of a wiggle .
job done .
if you are going to remove the steering wheel dont desturb the rotary coupler behind the steering wheel . (dont spin it round) otherwise the coil of wire inside it may snap when you turn on full lock when you have finished .
Old Oct 12, 2005 | 11:50 PM
jonnyturbo's Avatar
jonnyturbo
smack the front bumper with a sledge hammer, air bag will come out, job done
Old Oct 13, 2005 | 04:18 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
thanks guy swill get done now
A.t.p
Sep 29, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
The Enigma
Sep 29, 2015 10:31 AM
dave1960
Ford Fiesta
Sep 16, 2015 11:34 PM
