what part of a loom do you need to run engine
ON THE ROAD AGAIN
got mondeo removing and labeling full loom what part of the loom do i need or do i need it all,planning of bench running engine in garage
thanks tommy
thanks tommy
Loom
Your going to need the loom from the ignition and the engine bay. The key will be immobilised, so you will need the transponder attached to the ignition to start it or it will not start, the key has the red spot in it which is the chip. Hope this helps you. You will need most of it, best to take it allout.
big_Rad
15-09-2017 09:36 AM
muz
16-08-2015 12:57 PM
Zoggon
10-08-2015 10:39 AM
