FRST - revs dropping down too low when coming to a stop
hello!
just had a piper cam fitted and run in - the revs every so often drop down very low and 2 stalled the car
the car hasnt been driven apart from taking to the garage before fitting and it was fine then.
is this normal and do i need to adjust something?
Unplug the ecu for a minimum of 20 mins to reset its KAM settings, then drive around for 10 (ish) miles under a variety of conditions to let the ecu learn about the new cam. If this doesn't work it could be your VSS has failed (or did they disturb it when they fitted the cam?).
whats VSS? will try the ecu when i get back from this private job in 30 mins then
try disconnecting the idle speed control valve ( with the engine running ) then reconnect and let the engine idle for ten minutes, the revs may be a little up or down during this time.
Originally Posted by MATT-FRST
disconnecting the battery for a few hours didnt make any difference
and it seems to be idling even worse now
does it just need the fueling/emmisions set up after the cam fitting?
What cam was in the engine and what one has gone in? Also did it have new followers ?
replaced with piper fast road cam - it was a kit so yes it did
mine actually had this problem, doesnt do it anymore like, all i done was check all my hoses and choped one of them a little bit as it was a bit to long, one of the bolts holding my turbo in was a tad loose so tightend that up, i think im loosing air somewhere but unsure where, i turned up my rev's with the little screw in the arm that your accelerator goes to, ive added a pic to show you what i mean lol, i just turned mine up slightly.
on the picture where ive circled there a little crew under the bracket, you can make your rev's go up by turnin it but dont put them up to much
been to power engineering today to have the engine all setup and tested etc etc
he was playing about with what you circled so i think you were right
20% leakage in cylinder number 4 and a slight drop in compression
he also thinks i have a slight knock
so now i will be buying all the stuff for the zetec bottom end conversion
JoeyBoyden
Aug 18, 2015 05:56 PM
