rev limit on cosworth
Old Sep 27, 2005 | 08:14 PM
mrjonnie's Avatar
mrjonnie
Default rev limit on cosworth
Sorry but I'm new to the forum. I have a Westfield with a 2wd cosworth engine and have an adjustable rev limiter fitted. What is a good safe rev limit?
Thanks
Mr.J
Old Sep 27, 2005 | 09:36 PM
cossied's Avatar
cossied
Default revs
According to the manual max power is 6000rpm, max continuous engine speed is 6500 rpm max torque at 4500 rpm.
Old Sep 27, 2005 | 09:47 PM
DazC's Avatar
DazC
If standard rod bolts are fitted then don't take it over 7500 rpm. If you car doesn't produce any power up that high then it's pointless reving it that high anyway.
Old Sep 28, 2005 | 05:57 PM
mrjonnie's Avatar
mrjonnie
Thanks, it's getting set up at Motorsports Dev in Oct. I'll set it to 6000 until then see where the power is.
IAN RS2k
Aug 18, 2015 07:51 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
cozzy jeff
Aug 14, 2015 05:46 PM
Aug 14, 2015 07:29 AM
stevierob
Aug 11, 2015 09:08 PM
