FRST missfiring
Old Oct 24, 2005 | 11:42 PM
McCloud 85's Avatar
McCloud 85
Default FRST missfiring
The engine was rebuilt 2000 miles ago to standard spec apart from a fast road cam. It had new spark plugs and new magnecor leads. The car is running a bleed valve but only to reach 8psi as the amal valve was only letting the car boost to 3 psi.
The problem started occuring about 700 miles ago, after driving for a reasonable time the car would violently jerk forward when i put my foot down hard, and it reached about 5 psi of boost. Once the car did this once it will continue to till the end of the journey. Leave the car a few hours or so, even next day and the car will be fine again, may even have a journey without any problems, but once this missfiring happens once, it will do so until i stop the car.
I thought it was the MAP Sensor, i have just replaced it and on the way home it again missfired. iv have also swapped ignition packs and it has made no difference.
My question is where do i look next?
I just want to see the back of this problem now. Iv checked the sparks and all seems to be fine, apart from one which seemed to have unburnt fuel on, but cant see this has anything to do with it as it runs fine on idle before i turn it off.
Any help greatly appreciated
Dan
Old Nov 1, 2005 | 08:23 PM
power1234's Avatar
power1234
Default same problem mate
hi mate i had the same problem not so long ago, there is air gettin into your engine somewhere mate, my probs wos that sum 1 who had the car b4 i had it replaced all the gaskets but put the inlet manifold gasket on the wrong way round when i changed it the car woz fine mate
Old Nov 1, 2005 | 09:27 PM
LouRS's Avatar
LouRS
Mine is doing something similar but mine actuals dies as soon as you take your foot off the metal. Somethimes its fine but at the mo its not. I had a problem with my oil value seals which were changed not so long ago. Ive changed the trottel?sensor. Do you think I have a smiliar air leak somewhere?
If so how do you find it to sort it out?
Tnxs
Lou
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
bigryrs
Sep 5, 2015 02:57 PM
bigryrs
Aug 28, 2015 05:32 PM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
ginger1979
Jul 31, 2015 09:56 PM
