Standard RS Turbo Cam.....anyone know theyre stuff??
Right just bought a standard RS Turbo cam off eBay, its arrived all well and good, un-used
just wondering if anyone knows how to identify whether it is actually an RS cam, before i do the feedback thing, cant find the part number stamped on it
any help from anyone greatly appreciated
ok i tried measuring the cam, but the haynes manual quotes the amount of valve lift.
measrued the flat part of the cam......at 31.4mm(ish), and then with the lobe....37.4mm(ish), so from my calculations thats 6mm
The 1.3's have a higher lift than that! Think its probably to do with the rockers having an offset pivot point, increases the amount of lift.
So on that note... plan failed
anyone else know how i can tell if this cams genuine i really wanted to fit it saturday...?
Originally Posted by MD Cos
an rst cam is the same as the xr3i cam as far as i know?!
funny u should say it though
anyone know if an RST cam is the same cam the xr3i's have
unfortunately no there isnt a part number in the dizzy side, first place i looked aswell
got ford stamps on it thought so its definately a genuine cam
DOES ANYONE KNOW IF THIS IS TRUE AS I HAVE ONE AND WILL TRY THAT INSTEAD OF A PIPER CAM I HAVE GOT BUT WANT TO KNOW FOR SURE
It's true. Just don't know if S1 and S2 cams were different since mk3 XR3i and mk4 XR3i cams are not the same. I know the differences are minor in any case, just wondering.
As a spare nowadays, one cam is being sold for all these cars even from Ford.
Re: Standard rs cam
Originally Posted by RSKICKER
The cam is the same as a 1300 cvh mate
Matt Baxter
16-09-2015 08:30 PM
muz
16-08-2015 12:57 PM
