4x4 cossie front wheel bearing change - DIY ?
0-60 in 17 seconds (eek)
Just checked the workshop manual, and boy, do you need a lot of special tools, more specifically:
-One to remove seals.
-One to install seals.
-One to fit the hub back onto the driveshaft.
Are they all strictly necessary, can you get by without them...
Any advice much appreciated
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
I got away without using any special tools. Just be careful when removing and replacing the seals, but have you seen the torque setting for the hub nut? I think it’s up the high 250nm range.
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
Originally Posted by JohnP001
I got away without using any special tools. Just be careful when removing and replacing the seals, but have you seen the torque setting for the hub nut? I think it’s up the high 250nm range. ![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
How did you get the hub back onto the driveshaft though
JoeyBoyden
04-01-2024 02:36 PM
