breather and cossie engine (205 block)
hi,
i need to know where to connect a breather pipe (take off) to the cam cover ?
any clue ?
and where to connect the oil return pipe of the breather tank ? is it possible to connect it directly to the drain bolt of the sump ?
thanks
hervé 7.77
any clue ?
thanks
hervé 7.77
On the 205 and 200 blocks you can connect breather pipes to both sides of the block and not bother with a cam cover breather (which is better). You can use the existing turbo oil return from the new separator.
Yes you can return the oil seperator pipe to the sump, GGR sell an adapter to swap your sump plug for Aeroquip hosin, other tuners may do the same and for threaded/jubilee clip applications instead depending on money
Breathing from the original hole on the cold side and an adapter in the back of the block below the turbo will remove the need for drilling the cam cover as stated above. Again GGR can help, though they would prefer eroquip parts as they are shit at sorting cheaper jubilee clip parts in my experience. £££ though
big_Rad
15-09-2017 09:36 AM
