View Full Version : Ford Escort RS Turbo
- ST170 Brakes
- Fiesta RST intercooler
- what steering wheel?
- 1.6 cvh (carb model) to turbo please help
- rear lights
- car mats
- .48 exhaust housing
- Costs of your car
- Coil pos and negative
- what colour plugs go were?
- Std Exhaust
- turbozoe
- series 1 radiator.
- REAR LIGHT GASKETS
- problem starting when cold
- how to fit a air / fuel ration gauge to rst
- efi !!!!
- has anybody got....
- think my cars stuck on cold start
- surge?
- speedo cable..
- RS Turbo vs Seat Cupra??????????
- Jimmy boy
- Best master-cyl for cozzie brakes
- mk4 escort electric windows and central locking wiring up
- Best place to buy a paddle clutch
- Are mk3 and mk4 escort steering columns the same?
- sfs hoses
- AE pistons
- Zetec bottom end bearing clearence
- Gearboxes
- ST170 GEARBOX ONTO ZVH???????
- xr3 & s1 suspension the same??
- does a s2 turbo have a starter relay?
- s2 turbo HELP!!!
- Series2 wiring looms
- next mod ???
- Need new starter motor
- cossie brakes
- head chamber
- FRST XR3i, 2i Heads.
- MK3 ESCORT 2DR 2.0 SILVER TOP ZETEC HELP PLEASE
- starter motor question
- mk4 escort van rear leaf springs lower ??
- Getting Engine Back
- hi-tec in cradley... your opinions please
- distance between cvh exhaust ports question
- best place for parts....
- help please
- cossie brakes on a s2 ???
- help needed with my interior?
- oil pressure
- Suspension kit?
- tappety s2
- Escort RS Turbo block query
- T3 Turbo weight
- ERST Ecu's what do the colours mean?
- E85 JNR anyone know it?
- perspex windows
- overbore
- removing metering head
- Zetec Turbo engine, will these injectors work???
- idle problem
- series 1 on rl7`s pics please
- B 70 CVW Series 1
- Cigar lighter bulb problem
- RST wont idle when its hot
- braided brake hoses
- do efi escort looms disconnect like fiesta turbo looms?
- Chipped or not ?
- oil return pipe off s2 ?
- Fuel pump identification
- efi injector
- car wont idle when hot
- never mind
- Fuel Metering unit
- dumpvalves who uses then ??
- EFI conversion
- Series 1 RS Turbos didn't come with....
- T3 turbo from metro?
- my new s2 rst
- Will a mk3 gearbox fit a mk4
- mtx75 into s2
- piston picture
- s2 inter cooler
- Twin engined Mk3 Escort Shell on ebay
- fuel ecu
- head swop
- s2 struggles starting from cold
- what plugs and oil
- Ebay Mk3 cd
- Inlet manifold / throttle body gaskets?
- petrol pump
- Ebay Rs Turbo
- this turbo worth buying off ebay?
- leather retrim
- which compression ratio.???
- Diffrent in 90spec/88 spec spot brackets?
- Fuel Pump relay-short circuit
- White S2 Bonnet.....
- Thermostat
- Guess what i did!
- ecu chips,performance chips?
- delivery help
- sperical strut top mounts ,
- chipped ecu? help
- no boost!! help jus put engine bk in
- HELP!! IS MY HEAD DEAD???
- std clutch
- pistons and rods
- big valve heads
- i cant wait !!!
- zetec turbo efi??
- BAD RUNNING S2???
- wanted mk4 rs escort/ orion drop skirt
- what oil for running in period?
- TWO s2 problems
- inner window seals
- G440 utr
- Advice req!!
- what size wheels?
- looking in to carbon fibre dash for a series one turbo
- will a mk5 sunroof glass fit on a s2..?
- Zetec Turbo / Cosworth Management
- engine building what to go for
- anyone help going for more power
- rs16i rocker cover
- Anyone owned this RS?!
- RS Turbo Petrol!
- f440EDB
- Diesel gearbox
- high revs and getting hot! please help
- Pic Req Series 2 With Cut Down Number Plates
- are mk3/4 rear lower arms the same?
- Czech Republic New RS Turbo S2
- battery light
- ERST Wont Start From Cold !!!!!
- WANTED!! Rear view mirror NO NEED EBAY HAS SAVED THE DAY!!
- bleed valve
- gearbox options
- wastegate
- going for my 1st set up
- Auto Specialists Tubular manifold
- What pistons?
- cheap hybrid on ebay
- Are the focus exhaust manifolds better than escort cast ones
- what power from zvh turbo?
- Head Gasket
- welded in cages ??
- F415 LSH
- Exhaust manifold Zetec and CVH
- running probs on fiesta efi turbo in mk2 orion
- smokey on idle ?
- Ke Jet question
- Loads of Blue Smoke, Plz Read My Topic!
- bonnet bra ???
- is there a rs breakings near basildon?
- Coilovers.....
- what size wheels with -60mm drop
- Bumper Stripes
- water leaking in
- series 2 woes (again)
- Wheels
- RST daily driver?
- revs go up and down on idle?
- D203 GSG
- tips on setting gear linkages
- Zetec Turbo
- Mef Suspension
- pace ic
- s2 cold start wiring
- Website for efi conv...
- Value of wheels
- fly wheel
- efi
- s2 fan problem
- boost
- Ignition problems
- Alternator belt pullry!
- Rims Q
- where can i get low lowering springs?
- RST owners S1 prefered, need a favour....
- Knock sensor wiring
- Window seals?
- lag
- 2.1 zvh pistons...please help..
- Drive shafts
- Anyone know where do get mint standard rs turbo rims from?
- S1 ECU, Can i Run Blue-Red-Black ECU
- CAMS's
- Fuel Pump Bracket
- Best Cylinder Head ?
- sorted rs turbo
- Standard Intercooler. What they Good for?
- will a fiesta turbo bottom end fit a escort turbo cvh head?
- What dampers?
- Felpro Head Gasket
- non custom s2
- ANOTHER S2 PROBLEM (F**KING CAR)
- Running temperature
- 2.1 zvh. what pistons/rings ?
- What timing Belt fits ZVH
- RS Turbo ZVH series one engine problems
- Rear bulb holders
- Any one fitted a st 170 or focus RS engine in a mk3-4?
- Gated and baffled CVH sump
- TOP SPEED OUT OF RST.. THRUSH
- Micro Dynamics Fuel Enrichment (5th Injector Controller)
- Superchip
- selector rod and B&M
- Help! Car wont start!!
- No oil, batt or parking light on instrument panel? efi conv
- what oil ??
- chipped ecu question
- zetec escort turbo
- Which clutch
- fuel pressure regulator
- s1 grill
- blown 2 fuel relays????????????
- New T3 please!
- ACT gauge
- Cam Lifters Genuine Ford Vs Pattern Part
- steerin wheel
- 180 bhp
- gearbox!!!!!!!!!!!
- piston rings
- brake problem / washers & bolts
- coil pack bracket
- glowing manifold & turbo!!!
- boost problem
- polybushes
- Tips and tricks with building up engine
- New management, which way to go??????
- Co Pot and backfiring
- Arrghh Sump Gasket
- Brakes
- engine set-up
- Smoky ERST
- I bought a new projekt in sweden
- vernier pulleys, timing belt
- Plastic Windows
- caliper brackets
- Coilovers........
- Stunning standard, genuine low mile S2
- Fuel Pump / Filter Options ??
- evolution chip
- what injectors
- zvh
- cooling problems
